Sweeping the Rectangle Along a Line
Create a cuboid by sweeping the rectangle along a line (path).
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
Create a simple model using basic geometry and transformations to familiarise yourself with model creation in CADFEKO.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
Save the new model to file.
Learn to create variables, workplanes and primitive shapes. Continue by combining these basic entities and modifying their properties.
Define variables to create a parametric model.
Define a workplane to create an oblique plane. Workplanes simplify the process of creating geometry on oblique planes in comparison to using transforms.
Create a rectangle to be used in the construction of the horn.
Create a line to be used in the construction of the horn. This line will be used to create a cuboid by sweeping the rectangle along the line.
Create a flare primitive to be used in the construction of the horn.
Union the flare and cuboid to create the horn. The cuboid was created by sweeping a rectangle along a path.
Delete the redundant faces in the geometry to create a horn.
Add a wire feed to the model. As this example is only for demonstration purposes, this example does not cover the adding of a port or source to the wire feed.
Use the selection type tool to highlight an element in the 3D view.
Create an aperture (hole) in a face or region by using the subtract tool. Create the geometry to be removed and subtract it from the target part. The target is the part that is reduced by cutting away a section of the part.
The material definition with the properties for Teflon is added to the model from the media library.
Set the gobal XY workplane as the default workplane.
Create a cuboid and set the region medium to teflon.
Align the back face centre of the horn on the front upper edge of the cuboid.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled on an infinite substrate and then on a finite substrate.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
