Viewing the Results
View and post-process the results from the characterised surface in POSTFEKO.
31x31 FSS element sheet | RAM | Simulation time |
Characterised surface - RL-GO | 13 MB | 39 sec |
Full solution - MLFMM | 542 MB | 8 min 42 sec |
Note the significant difference in computational requirements. Both simulations are run in parallel using four cores. A factor of 42x reduction in memory and 13x in simulation time is achieved using the characterised surface approach.
A practical example where the characterised surface is extremely useful is shown below: an FSS nosecone radome is represented using this feature. Due to the size and complexity of the structure, it becomes prohibitive to model and solve with a full wave solution, while the characterised surface approach is relatively straightforward and efficient.
Figure 1. E-field above the characterised surface for 2 theta angles.
Figure 2. Full model of the 31x31 element FSS sheet solved with MLFMM.
Figure 3. E-feld distribution through an FSS radome calculated using a characterised surfaces.
