Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Use the model considered in Pin-Fed Patch: Broadside Pattern by Phase Shift Definition and rename the file.
Modify the periodic boundary condition.
- Specify manually the phase shift to be u1=−61.56° and u2=0° for the two directions.
