Specifying the Array Layout
Specify the number of elements and offset between the elements.
Figure 1. The Array layout dialog.
  1. In the Number of elements in X direction field, enter a value for the number of elements.
  2. In the Number of elements in Y direction field, enter a value for the number of elements.
  3. In the Offset along X axis field, enter a value for the offset between the elements.
  4. In the Offset along Y axis field, enter a value for the offset between the elements.
  5. Click OK to close the Array layout dialog.
    The Import excitation values dialog is displayed.
