Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Use a custom mesh to accurately resolve the geometry.
  1. Set the Mesh size equal to Custom.
  2. Set the Triangle edge length equal to 4 cm.
  3. Set a 3 cm local mesh size on the region inside the elliptical phantom.
  4. Mesh the model.
