Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
- Use the same mesh settings as for Pin-Fed Patch: Broadside Pattern by Phase Shift Definition.
- Mesh the model.
