Make Manifold
Create a manifold solid from non-manifold objects (including trimeshes) by deleting excess faces, edges, and vertices.
This is a "smart" intersect tool that automatically deletes excess faces, edges, and vertices. An object is defined as manifold when its edges are shared by not more than two surfaces.
