Storing a Local Copy of a Dataset
Store a local copy of the underlying data that is represented by the 3D simulation result. By storing a local copy, you can modify the existing model and compare the old results to new results.
  1. Select the 3D view and 3D view simulation result (either in the 3D view or the result palette) that you want to store.
  2. On the 3D View contextual tabs set, on the Result tab in the Manage group, click the  Store a copy icon.
    A new entry under Stored data is created that is accessible from the project browser or the ribbon.
    Figure 1. Accessing stored data from the ribbon.
