Spectral Extrapolation Techniques
When performing a time analysis where lower frequencies are not simulated and need to be estimated, different options are available to extrapolate the spectral component of the simulation result to 0 Hz.
On the Time analysis tab, in the Add time domain results group, click the dialog launcher.
Note: The adaptive sampling technique provides more accurate low frequency
extrapolation than linear interpolation but can be less predictable.
