Display Options for Rays
View the ray display options for ray launching geometrical optics (RL-GO) and uniform theory of diffraction (UTD).
The UTD ray display settings are available on the 3D View contextual tabs set, on the Result tab, in the Rays group.
The options are enabled on the POSTFEKO ribbon if a ray result is displayed in the 3D view. To obtain the ray file, you must select the option to export the ray file in CADFEKO.
Icon | Icon text | Description |
Ray lines | Show / hide ray lines. | |
Ray numbers | Show / hide ray numbers. Note: A ray number is a unique number or ID associated
with a ray.
Group numbers | Show / hide the ray group numbers. Note: A ray group number is a unique number or
ID associated with a group of rays which all belong to the same source, start at the
same location or end at the same observation point.
Intersections |
Show / hide ray intersection points. The following abbreviations are used in the 3D view:
Threshold | Specify the visibility threshold of the rays as a percentage.
Colour magnitude | Enables / disables the display of rays in colour according to its magnitude. |
