Optimisation
Optimisation data such as optimised parameters, goals, global goals and masks can be viewed on a Cartesian graph after OPTFEKO was used to calculate the results.
On the Home tab, in the Add results group, click the  Optimisation icon.
Figure 1. Example of the result palette for optimisation. The Independent axis (Horizontal) is set as the Optimisation run number.
