Display Options for Contours
View the display options for contours. Contour lines are curves that connect points where a function has identical values.
The contour display settings are available on the 3DÂ View contextual tabs set, on the Result tab, in the Contours group.
Icon | Icon text | Description |
Show contours | Show / hide contour lines. | |
Colour | Set the colour of the contour to any value, or the colour is linked to the magnitude of the displayed value. | |
Position | Specify the number of contours or the contour values. |
