Sampling Settings for Continuous Far Fields
View the sampling options for sampling 3D continuous far fields.
On the 3D View contextual tabs set, on the
Result tab, in the Rendering group, click the
Sampling settings icon.
Figure 1. The Continuous sampling settings dialog.
The following sampling options are available:
| Sampling Setting | Description |
| Auto | The default rendering option automatically determined from sampled data. |
| Request points | Disables continuous sampling and shows only the requested far field points. |
| Specify angular resolution | Specify a custom sampling interval. |
