Custom Point Annotations
A number of custom point annotations definitions are available for a Cartesian graph that allows you the flexibility to annotate any point of interest on the graph.
On the Cartesian context tab, on the Measure tab, on the Custom annotations group, click the  Points icon. From the drop-down list, select the type of annotation you want to use.
Table 1. The custom point annotation definitions available in POSTFEKO.
Icon Icon text Description
Global maximum Place an annotation at the global maximum.
Global minimum Place an annotation at the global minimum.
Specify independent axis value Place an annotation at a specified independent axis value.
Second maximum Place an annotation at the second maximum.
Second minimum Place an annotation at the second minimum.
Other Opens a dialog where you can specify any of the following custom point annotations:
  • Global maximum
  • Global minimum
  • First local maximum
  • First local maximum to the left
  • First local maximum to the right
  • Greatest local maximum
  • Greatest local maximum to the left
  • Greatest local maximum to the right
  • First local minimum
  • First local minimum to the left
  • First local minimum to the right
  • Greatest local minimum
  • Greatest local minimum to the left
  • Greatest local minimum to the right
  • Value at given horizontal position
  • Define independent value
