Create a work surface from a constrained surface. The work surface is used to define
surface curves in the U′V′ parameter space of this surface.
On the Windscreen tab, in the
Surface preparation group, click the
Work surface icon.
With the Reference face field
active, click on the constrained surface in the 3D view.
In the Offset field, specify the work surface offset
from the constrained surface.
Click Create to create the work surface and close
the dialog.
The defined work surface is displayed in the
model tree.
Note: There is no link between a constrained surface and a work surface after the work surface is
created.
When attempting to modify an existing work surface, the Reference face field will be
empty.
