NURBS
Create a non-uniform rational basis spline (NURBS) surface.
Tip: Press S,5 to use the shortcut key.
Specify the order of the Bézier curves | The degree of the Bézier curve in the Uʹ direction and Vʹ direction. |
| Point position | The position of each surface control point is specified. | |
| Weight | The weight of each surface control points is specified. |
