Cylinder
Create a cylinder.
On the Construct tab, in the Create solid group, click the  Cylinder icon.
Tip: Press C,4 to use the shortcut key.
Method 1: Base centre, radius, height
Base centre (B) The centre of the cylinder base.
Radius (R) Cylinder radius (parallel to the UV plane).
Height (H) Cylinder height in the N direction measured from B.
Method 2: Base centre, top centre, radius
Top centre (T) The centre of the cylinder top.
Radius (R) The cylinder radius (perpendicular to the line from B to T).
