Add an error estimation request. Error estimation is an a-posteriori error indicator
which gives feedback on the mesh quality. The mesh quality is determined by testing the
solution against an unconstrained physical test.
On the Request tab, in the
Solution requests group, click the Error estimate icon.
From the drop-down list, select one of the following:
To request error estimates on all mesh elements in the model, select
All mesh elements.
To request currents only on triangles, select Only error
estimates on triangles.
To request error estimates only on segments, select Only
error estimates on segments.
error estimates on tetrahedra.
To request error estimates only on mesh elements with specified labels,
select Only error estimates on specified
labels.
[Optional] Select the Export error estimates to *.out
file check box to export the error estimates to the .out file.
In the Label field, add a unique label for the
request.
Click Create to request the error estimates
results and to close the dialog.
