Edge Ports
Edge ports can be applied to an edge defining the boundary between two sets of faces.
Faces referenced in the port definition must belong to the same part for a valid port definition.
Figure 1. The edge port in the 3D view. The side of the positive faces is indicated with a red cylinder and the negative faces with a blue cylinder.
