Creating a Cable Port
Apply a cable port to a cable harness.
- Open the cable schematic view for the cable harness of interest.
On the Source/Load tab, in the
Ports group, click the
Cable port icon.
The cable port symbol is added to the active cable schematic view. - Connect the port to other schematic elements.
From the right-click context menu, select Properties to
change the label for the cable port.
The Modify cable port dialog is displayed.
Figure 1. The Modify cable port dialog. - In the Label field, add a unique label for the cable port.
- Click OK to apply the new label and close the dialog.
