OPTFEKO Options
Specify OPTFEKO command-line parameters using the GUI.
Restart from solver run
This option can be used if the optimisation process was terminated or interrupted and temporary files are available. Restart the optimisation at the number of the last completed optimisation iteration. No changes may be made to the model before restarting the optimisation process.
Delete all files (except optimum)
This option deletes all temporary files.
Note: Files related to the optimum model and solution are not considered temporary files and are not deleted.
Number of processes to farm out
This option allows you to specify the number of the process used for an optimisation run when farming out the kernel solution.
Configure
Specify the hosts and processes to be used when farming out the kernel solution.
Figure 1. The Machines configuration dialog.
