Finite Antenna Arrays
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Create the base element (antenna) and create a linear, planar, cylindrical or circular
finite antenna array with ease. Add custom antenna array elements to create complex and arbitrary
finite antenna array structures.
The DGFM solver method considers the self-coupling, mutual coupling and the edge effects of the finite array, but only uses the computational resources equivalent to solving the base element.
Note: All structures in the model (except for infinite planes) are the base element when creating
a finite antenna array.
