Create a custom array element. Use a custom array element to create an
irregular-spaced array.
On the Construct tab, in the Structures
group, click the Planes/arrays icon. From the drop-down list, select the Custom array element icon.
Under Origin, enter the position of the workplane using
one of the following methods:
- Enter the coordinates for the origin manually.
- Use point entry to enter the coordinates for the origin from the 3D view.
Under Excitation, in the Magnitude
scaling field, enter the excitation magnitude for the
element.
Under Excitation, in the Phase offset
(degrees) field, enter the phase offset for the element in
degrees.
In the Label field, add a unique label for the antenna
array.
