Troubleshooting the Server
If the server does not start, take the following steps:
Ensure you have a valid RLM license:
% rlmstat -a % rlmstat -avail
Check if the server for your project is already running on the same machine.
Note: Do not start a VOV project server more than once.For example:
% vovproject enable project % vsi
- Check if the server is trying to use a port number that is already used by another vovserver or another application. VOV computes the port number in the range [6200,6455] by hashing the project name. If necessary, select another project name, or change host, or use the variable VOV_PORT_NUMBER to specify an known unused port number. The best place to set this variable is in the setup.tcl file for the project.
- Check if the server is trying to use an inactive port number that cannot be bound. This can happen when an application or the server terminates without closing all its sockets.
When a port is not available, the server will exit with a message similar to
the following:
...more output from vovserver... vs52 Nov 02 17:34:55 0 3 /home/john/vov vs52 Nov 02 17:34:55 Adding licadm@venus to notification manager vs52 Nov 02 17:34:55 Socket address 6437 (net=6437) vs52 ERROR Nov 02 17:34:55 Binding TCP socket: retrying 3 vs52 Nov 02 17:34:55 Forcing reuse... vs52 ERROR Nov 02 17:34:58 Binding TCP socket: retrying 2 vs52 Nov 02 17:34:58 Forcing reuse... vs52 ERROR Nov 02 17:35:01 Binding TCP socket: retrying 1 vs52 Nov 02 17:35:01 Forcing reuse... vs52 ERROR Nov 02 17:35:04 Binding TCP socket: retrying 0 vs52 Nov 02 17:35:04 Forcing reuse... vs52 ERROR Nov 02 17:35:04 PROBLEM: The TCP/IP port with address 6437 is already being used. POSSIBLE EXPLANATION: - A VovServer is already running (please check) - The old server is dead but some of its old clients are still alive (common) - Another application is using the address (unlikely) ACTION: Do you want to force the reuse of the address?
In this case, do the following:-
List all VOV processes that may be running on the server host and that
may still be using the port. For example, you can use:
% /usr/ucb/ps auxww | grep vov john 3732 0.2 1.5 2340 1876 pts/13 S 17:36:18 0:00 vovproxy -p acprose -f - -b john 3727 0.1 2.2 4816 2752 pts/13 S 17:36:16 0:01 vovsh -t /rtda/VOV/5.4.7/sun5/tcl/vtcl/vovresourced.tcl -p acprose ...
Wait for the process to die on its own, or kill the process with the
command vovkill. For example:
% vovkill pid
- Restart the server.
