Environment Variables
Variable Name | Used By | Description |
CLEARCASE_ROOT | ||
DISPLAY | vovsh GUI nc run -Ix |
Name of the X display. It is required to use the graphical user interface. |
HERO_EMUL | HERO hero |
The name of a specific emulator in Hero. Available at runtime |
HERO_HOST | HERO HERO_PORT |
Together with HERO_PORT, used by some Hero utilities to locate the HERO wrapper for one emulator. Each emulator has a wrapper and the wrapper can be found with HERO_PORT and HERO_HOST. This variable should not be set by the user. |
HERO_PORT | HERO HERO_HOST |
Together with HERO_HOST, it is used by some Hero utilities to locate the HERO wrapper for one emulator. Each emulator has a wrapper and the wrapper can be found with HERO_PORT and HERO_HOST. This variable should not be set by the user. |
HERO_VENDOR | HERO hero |
One of the supported Hero vendors (currently, one of zebu palladium veloce). |
KRB5CCNAME | nc kerberos | The name of the Kerberos Credential Cache file. |
LD_LIBRARY_PATH | vrt | |
LD_LIBRARY_PATH_64 | vrt | |
LD_PRELOAD | vrt | Used on Linux to preload vovrti.so, the interception library. |
LM_PROJECT | nc | This variable is used by FlexNet Publisher to specify a project for a
checkout. It is also used by nc run to define the default value
of the jobproj field of a job. See also VOV_JOBPROJ and
RLM_PROJECT. |
LM_VAR_NAME | vovgetflexlmdaemons vwrap vw |
Specify the name of the environment variables to be set on the basis of the grabbed resources. This variable is used by the wrapper vw and by the script vovgetflexlmdaemons.tcl. The variable VOV_LM_VARNAMES is preferable to this. |
LOGNAME | Normally defined in the standard environment (POSIX). | |
NC_AUDIT_FILE | nc | Specify a file in which to log NC CLI commands for auditing. The file must be
writable by the user issuing the nc command. The variable may
contain a single reference to another, which will be expanded to compute the file
pathname.
NC_CONFIG_DIR | nc/wx utilities
ncmgr/wxmgr LSF emulation utilities |
Specify the directory that contains the NC/WX queue configuration file. This
location must be a shared network location that all clients can read. The default
location is $VOVDIR/local/vncConfig. Because the configuration
is created by ncmgr/wxmgr, the variable must
be set before running those utilites to create a queue. Afterward, the variable must
be set in the admin-defined, shell-specific vovsetup.csh|sh|tcl
script (UNIX), or vovinit.bat (Windows) in
$VOVDIR/local, or otherwise in all user environments, such as
through a .cshrc/.bashrc script.
NC_DEFAULT_JOBCLASS | nc run nc jobclass |
This is a useful variable to speedup job submission with nc run. If this variable is set, use its value to find out the default jobclass. This is should be the same as the property NC_DEFAULT_JOBCLASS attached to Object 1. |
NC_FIFO | nc run | Use this variable if you are running a lot (thousands) of nc
commands from the same shell. This variable points to a file that is used in a
mkfifo command to create a fifo. When nc is
run, it checks that fifo. If it does not exist, it creates it, and then waits for
commands to arrive on that fifo. If it does exist, it sends the arguments of
nc run to the fifo. The benefit is that we bypass the
initialization of the Tcl interpreter.
NC_LIST_FORMAT | nc | Specify the default format for nc list. |
NC_LOGDIR | nc run bsub |
Specify the directory to be used to store the logs. This is used also by the
LSF emulation script
bsub.
Old names also supported: VNC_LOGDIR, FTNC_LOGDIR. |
NC_LOGDIR_PERMS | nc run bsub |
Specify the permissions for the directory to be used to store user logs. Must
be specified in UNIX permissions format. Default value is 0775. This is used also by
the LSF emulation script
bsub.
NC_NOLOG | nc run bsub |
Internal variable used only to disambiguate the environment for interactive jobs. Do not set this variable. |
NC_OLDQUEUE | nc ncmgr |
Used to migrate from an old queue to the new queue. |
NC_OLDVERSION | nc ncmgr |
NC_QUEUE | nc
ncmgr wx wxmgr |
Specify the name of the queue used by the nc and wx commands. This can be specified as a simple name (e.g. XXXX), in which case the system sources the file in $VOVDIR/local/vncConfig/XXXX.tcl, or it could be the full path to the setup.tcl file in the .swd. If not specified, the value used is "vnc". |
NC_RUN_ARGS | nc | Specify the default arguments for nc run. The arguments in this variable are prepended to the arguments passed on the command line. Use NC_RUN_ARGS_AFTER is you want to append arguments to the command line. |
NC_RUN_ARGS_AFTER | nc | Specify some default arguments for nc run. The arguments in this variable are appended to the arguments passed on the command line. Use NC_RUN_ARGS is you want to prepend arguments to the command line. |
NC_RUN_BLOCKING_STDOUT | nc | Experimental. Controls whether the stdout/stdin descriptors in an interactive
job are to be set to non-blocking or not. Typical usage in situations
like:
NC_SNAPSHOTDIR | nc ncmgr |
Specify the directory to be used to store the environment snapshots. This
variable can be the path to a directory or a symbolic value such as
NC_SNAPSHOTDIR_PERMS | nc run bsub |
Specify the permissions for the directory to be used to store the environment
snapshots. Must be specified in UNIX permissions format. Default value is 0775. This
is used also by the LSF emulation script
bsub.
NC_SNAPSHOTFILE_PERMS | nc run bsub |
Specify the permissions for the environments snapshot files. Must be specified
in UNIX permissions format. Default value is 0664. This is used also by the LSF
emulation script
bsub.
NC_STOP_SIGNALS | nc stop bkill |
Specify the signals sent by nc stop. This is a
comma-separated list of signals to be sent to the processes in the job. The signals
include TERM INT KILL HUP USR1 USR2 CONT TSTP. In addition, EXT is supported in
the format EXT:SIGNAL:INCLUDERX:EXCLUDERX:SKIPTOP (notice that we use the colon
':' instead of ',' commas).
Examples:
In the case of nc stop, instead of this environment variable, you
can use a property on a job with the name NC_STOP_SIGNALS and with the same syntax.
The signals are sent to the job with a delay determined by VOV_STOP_SIGNAL_DELAY or
NC_STOP_SIG_DELAY, and is 3 second by default. If both NC_STOP_SIGNALS and
VOV_STOP_SIGNALS are present in the environment, the value of VOV_STOP_SIGNALS will
be used. If both NC_STOP_SIG_DELAY and VOV_STOP_SIGNAL_DELAY are present in the
environment, the value of VOV_STOP_SIGNAL_DELAY will be used.
NC_STOP_SIG_DELAY | nc stop bkill |
Specify the delay between signals sent by nc stop. In seconds. The default value is 3 seconds. If both NC_STOP_SIG_DELAY and VOV_STOP_SIGNAL_DELAY are present in the environment, the value of VOV_STOP_SIGNAL_DELAY will be used. |
NC_SUSPEND_SIGNALS | vtk_job_control | Specify the signals sent by vtk_job_control when action is
SUSPEND This is a comma-separated list of signals to be sent to the processes in the
job. The signals include TERM INT KILL HUP USR1 USR2 CONT TSTP. In addition, EXT
is supported as a signal in the format EXT:SIGNAL:INCLUDERX:EXCLUDERX:SKIPTOP
(notice that we use the colon ':' instead of ',' commas).
Examples:
A
property on a job with the name SUSPEND_SIGNALS can be used with the same syntax. If
both NC_SUSPEND_SIGNALS and VOV_SUSPEND_SIGNALS are present in the environment, the
value of VOV_SUSPEND_SIGNALS will be used. The signals are sent to the job with a
delay determined by
vtk_job_control -delay option. |
NC_TEST_KERBEROS | nc kerberos | Used only for testing. If set to any value, then the kerberos code assumes that the Kerberor Credential Cache file is good instead of testing it with klist. Adds verbosity to vovbytepump (only useful to developers). |
NC_URL | nc run | This is a useful variable to speedup job submission with nc
run. If this variable is set, use its value to compute the URL for the
submitted job instead of asking the server. This saves one round-trip from client to
server. Also consider NC_DEFAULT_JOBCLASS and NC_VALID_DIRECTORIES
Example:
NC_VALID_DIRECTORIES | nc run | This is a useful variable to speedup job submission with nc
run. If this variable is set to a space-separated list of directories,
we use its value to determine valid submission directories. This is supposed to be
the same as the property NC_VALID_DIRECTORIES attached to Object 1. Also consider
NC_URL and NC_DEFAULT_JOBCLASS. Example 1: Example 2: |
PATH | Normally defined in the standard environment (POSIX). | |
RLM_LICENSE | Specify the path to the Reprise license. The default is $VOVDIR/local/license.rlm | |
RLM_PROJECT | nc | This variable is used by Reprise to specify a project for a checkout. It is also used by nc run to define the default value of the jobproj field of a job. See also VOV_JOBPROJ and LM_PROJECT. |
RLM_QUEUE | wa | If set to any value, the request for a feature will be queued by RLM instead of being denied. Only use this variable for WorkloadAnalyzer. |
SECURITY_LEVEL | vovsh | If set, this variable can lower the security level of the vovsh. This variable
can never increase the security level, which is determined by
security.tcl. The variable is an integer. The common values
are
SHELL | ves
vovprompt vovsetupuser |
TEMP | vovbytepump
VovTmpFile |
Normally defined in Windows to point to a writable directory for temporary files, this variable is used also on UNIX in the Tcl procedure VovTmpFile. |
TZ | Normally defined in the standard environment (POSIX). | |
USER | Normally defined in the standard environment (POSIX). | |
VNCSWD | nc
ncmgr |
Normally used to specify the server working directory for Accelerator. Its
value is normally $VOVDIR/../../vnc. For installations
including a mix of UNIX and Windows NT, the value of VNCSWD is
normally set also in $VOVDIR/local/vovinit.bat which is
executed as part of the initialization sequence on Windows NT. |
VOVARCH | Identifies the application architecture. It is computed by the tool vovarch. It is normally set in $VOVDIR/etc/vovrc.{sh,csh,bat}. | |
VOVBUILDOPTIONS | vovmake | Pass options to be used by vovbuild inside of vovmake. |
VOVCLEARCASE | If set to "ENABLED", this variable activates the ClearCase routines to track dependencies on both the "view extended name" and the "version extended name" of a file. | |
VOVCONSOLE_SUBMIT_CMD | vovconsole | Define that environment variable so that the vovconsole automatically bsubs
itself. Typical usage:
Use:
to
check the value of that variable as You may also want to
use:
to debug submission errors. |
VOVDIR | The root of the VOV distribution tree for a specific architecture. VOVDIR always includes the architecture. From $VOVDIR, you can get the binaries in $VOVDIR/bin. | |
VOVEQUIV_CACHE_FILE | Provides the ability to override the default behavior of using a server-side cache of path equivalence information. Set to a value of "legacy" to instruct clients to read the file directly. This is a legacy method that requires that all clients have access to the server working directory so they can parse equiv.tcl file for entries, and read/write access to the equiv.caches directory so the entries can be written to a host-based cache file for future use. Set to a custom cache file path to instruct clients to read a specific cache file only. This is a special method used in corner cases where directories may not be the same but should be forced to be considered the same. This is utilized mainly by Monitor agent single-file distributables. | |
VOVGMAKE | vovmake | Specify the path to gmaek_with_vov_extension |
VOVLSFINFOD | vsm
nc mon |
This variable should have the form HOST:PORT and represents the way to access the vovlsfinfod daemon. The PORT is normally 6006. |
VOVLSF_USE_NC | LSF emulation utilities | Set to 0 to prevent LSF emulation from interacting with Accelerator. This is only required when wanting LSF emulation to interact with a FlowTracer server instead of Accelerator. |
VOVMAKEDOCLEANUP | vovmake | If set to 1, do not cleanup the intermediate Flow file caused by dumping the makefiles rules. |
VOVPROJECT_SUBMIT_CMD | vovproject
vovserver |
This variable contains the command used by vovproject to
launch the vovserver, for example using bsub. Typical usage:
Since
this variable often has a value with tricky characters, we suggest you
use:
to
check the value of that variable as For debugging purposes, you
may also want to use interactive options like the option -I in
this
example:
VOVRTILIB | Control the name of the dynamic library used for Runtime Interception. By default, the library is $VOVDIR/lib/vovrti.so. This variable is used mostly by developers. | |
VOVRTILOGFILE | Specify location of log file for debugging information about the behavior of VOVRTI. | |
VOVSAVEPROMPT | vovprompt
ves veprestore |
Used to store the original value of the prompt. |
VOVSETUPFILE | indirect taskers
nc run ID ... |
If this variable is set, then the indirect tasker use its
value when submitting a job from FlowTracer to Accelerator. Specifically, the value
of VOVSETUPFILE becomes the parameter for the PROJECT environment. In other words,
the indirect tasker submits a job of type vrun
with environment "PROJECT($VOVSETUPFILE)" |
VOVTMPVAR | vovtasker | Temporary variable used only in the initialization of the multi-environment subsystem. Do not use this variable because it is likely to be over-written. |
VOV_32BIT | vovarch | See VOV_BIT_MODE instead. |
VOV_ALARM | vovgetgroups | Used by vovgetgroups to avoid hanging indefinitely. The default value is 10 seconds, but there is no maximum upper limit. |
VOV_BACKGROUND | Sets the background color of the GUI and of all the browser pages. If not set,
the color is chosen automatically by hashing the project name so that each project
has a slightly different background. The background should be light. Examples:
VOV_BIT_MODE | vovarch | This variable is used to select which architecture to use on 64-bit Linux
machines and affects the output of the vovarch command. By
default the command returns "linux64" on 64-bit Linux machines. However, these
machines can also run 32-bit binaries as long as the standard 32-bit libraries are
included in the Linux installation. To force a 64-bit machine to run Altair
Accelerator in 32-bit mode, set this environment variable to "linux" before
sourcing the shell-appropriate vovrc setup script. Example:
VOV_BJOBS_JOBID_WIDTH | bjobs | Used to override the default job ID column width of -7. Characters to the left of the width limit are truncated and replaced with an asterisk to indicate the truncation. Pass a negative integer for left justification. Pass a positive integer for right justification. |
VOV_CAPSULE_DIR | vov
vw vrt vw2 vtrace |
Specify a list of directories where capsules can be found. The list is
separated by a colon ':' on Unix and by a semicolon ';' on Windows. The other
directories that are searched are:
VOV_CGROUPS_ENABLE | If this variable is set to 1 in the environment of vovtaskerroot, then the CGROUP:RAM capability is enabled.
VOV_CHANNEL | VIL | Full path to the vovchannel binary. Defaults to $VOVDIR/bin/vovchannel. |
VOV_CHANNEL_OPEN | VIL
vovchanneld |
Used internally by VIL and by vovchannel. Should not be set by the user. |
VOV_CLIENT_NAME | If set, this variable is used to set the name field for a
client. The client name is only visible from the /admin?page=clients browser page. |
VOV_CONFLICT_CONTROL | vw
vrt vov vtrace vw2 |
If there is a conflict, check the value of this variable. If it is ABORT or CONTINUE, behave correspondingly. If it has another value, print a warning and return ABORT. If the variable is not set, in case of conflict a dialog will be posted to determine what to do. This variable is used to control Runtime Tracing in case of conflict. If the behavior is ABORT, then the tool is aborted at the first conflict. If the behavior is CONTINUE, then the tool continues to execute. |
VOV_DB_APP | This variable can be used to select different database configurations for the
same VOV project. In the file *.swd/db/config.tcl, use
VovSQL::getDbApp to return the value of this variable. |
VOV_DEBUG_BYTEPUMP | vovbytepump | Adds verbosity to vovbytepump (only useful to developers). |
VOV_DEBUG_ENV | vel
ves |
Adds verbosity to vel and ves. Set the value to 1 for debugging, to 0 to disable debugging. |
VOV_DEBUG_EQUIV | vw2
vov vrt vtrace vw vovtasker vovtaskerroot |
Adds verbosity to equivalence handling module. |
VOV_DEBUG_FLAGS | All VOV clients | This variable is to be used only by developers and experts. It controls
debugging output to monitor communication between clients and server. It also
controls verbosity of some modules. Here is a quick reminder of the possible values
for this variable.
VOV_DEBUG_GETGROUPS | vovtasker | Adds verbosity to vovgetgroups. |
VOV_DEBUG_LDAPAUTH | vovserver
vovldapauth |
Adds verbosity to LDAP authentication procedure. |
VOV_DEBUG_LIMITS | vw2
Adds verbosity to tools that set the resource limits like cputime and coredumpsize. Affects vovtasker and vw2. |
VOV_DEBUG_MD5 | vw
vov vrt vw2 |
Adds verbosity to wrapper code used to implement MD5 based barriers. Any value of this variable activates the verbosity. Unset the variable to disable. |
VOV_DEBUG_NO_START | vovtasker | Provides debug info for jobs launched by taskers that do not start successfully. Causes the tasker to run the vov_diagnostic_no_start script to generate detailed debug information on why a job did not start. Set to 1 for coarse info (most common setting). Set to 2 for more detail (should only be done for brief periods on selected taskers due to high server load). |
VOV_DEBUG_ORIGARGS | nc | Enables the capturing of the original argument list to nc run and stores it as a property (ORIGARGS) for debugging purposes. Set this variable to 1 in the submit shell or NC setup.tcl file to enable. Do not use this function unless it is needed, however, since it will cause the server to consume a significant amount of RAM with higher workloads. |
VOV_DEBUG_PAMAUTH | vovserver
vovpamauth |
Adds verbosity to pam authentication procedure. |
VOV_DEBUG_PTY | vovtasker
vovsh |
Adds verbosity to PTY code, used in vovsh and vovtasker with interactive jobs that require a PTY. Set the value to 1 for basic information, or to 2 to see every character being sent. |
VOV_DEBUG_RLM | vovtasker
vovsh vovserver |
Adds verbosity to RLM code. Set to 1 to enable, to 0 to disable. |
VOV_DEBUG_TASKER | vovtasker | Adds verbosity to vovtasker. Only useful for debugging. Also slows down job execution by 10 seconds to allow time to connect a debugger to the subtasker. |
VOV_DEBUG_TASKER_CHDIR | vovtasker
vovtaskerroot |
Used to troubleshoot problems with subtasker changing to the run directory. Only useful for debugging, should normally be unset. Debugging output appears in vovtasker's log file. When set, activates a call the script vov_diagnostics_chdir whenever a vovtasker is unable to start a job because the working directory for the job cannot be reached. This type of errors can be hard to diagnose, for example in cases when the error is caused by slow or overloaded auto-mounters. |
VOV_DEBUG_TASKER_GROUPS | vovtasker
vovtaskerroot |
Adds verbosity to the code used to compute os groups for users. |
VOV_DEBUG_TASKER_NC | vovtasker | Adds verbosity to the indirect NC tasker. Set variable to 1 to enable, to 0 to disable. Default is 0. |
VOV_DEBUG_SUBSERVER | vovserver | Adds verbosity to vovserver code when running in "subserver" mode. |
VOV_DEBUG_SYMLINKS | vw vrt vov |
Adds verbosity to code used to expand symlinks. Often used in conjunction with VOV_SYNC_CACHE_DIR Set the value to 1 to activate, unset to deactivate. |
VOV_DEBUG_VTKGRAPH | vovsh GUI |
Adds verbosity to graph widget in vovsh. |
VOV_DELAY_BEGIN | vw | Delay job execution after start by specified number of seconds. Used to compensate for offset in filesystem clock. |
VOV_DELAY_END | vw | Introduce a small delay after the job is done and before checking the timestamps of the outputs. |
VOV_DELAY_FIRE | vw | Delay tasker firing by specified number of seconds. Used to compensate for offset in filesystem clock. |
VOV_DISABLE_DST_CHECK | Disable the code used to compensate for "Daylight Saving Time" overcompensation bug on Windows NT. By default, the code is active. | |
VOV_DISABLE_SHARED_MEMORY_LOOKUP | vovtaskerroot vovtasker |
Instructs the tasker to skip the lookup of shared memory information when updating job statistics. Specify 1 to disable. Default: 0 (shared memory lookups are enabled). |
VOV_DISABLE_VIL_REDIRECT | VIL
vovchannel |
Disable redirection of stdout and stderr through VIL and vovchannel. |
VOV_EDITOR | vovsh
GUI |
Used by the GUI to decide which editor to use. If not set, it defaults to
write on Win64 and to xterm -e vi on UNIX. |
VOV_ENV | ves
vw |
Used to support multiple environments. Stores the name of the current environment. If it is not set, the environment name is assumed to be DEFAULT and the multiple environment support is disabled. |
VOV_ENV_DIR | vel
ves vovtasker |
Used to support multiple environments. Its value is a list of the directories that contain the environment scripts. The list elements are separated by colons ':' on UNIX and by semicolons ';' on Windows NT. |
VOV_ENV_SOURCE | vwrap | Used by vwrap to source the environment snapshot. Should not be set by the user. |
VOV_ENV_STRICT | ves | By default, ves ignores errors when switching environments. When this variable is set to a non-zero value, any environment switch which writes to stderr will be strictly treated as an error and the environment switch will fail. |
VOV_EXCLUDE_FILES | vw
vov vrt vw1 |
List of files containing exclusion rules. If this variable is not set, the wrappers only read the exclude.tcl file in the SWD directory. Missing files in the list are silently ignored. Errors in sourcing the files are also silently ignored. The files in the list are separated by colons ':' on UNIX and by semicolons ';' on Windows. |
VOV_FAIL_ON_CONFLICT | Use VOV_CONFLICT_CONTROL instead. If there is a conflict, cause the job to fail right away. Do not pop-up a dialog or wait for user input. Especially useful in the environment for taskers in Windows-NT. | |
VOV_FDL_ONLY | viltool
VovInput VovOutput VovFdl VovResources |
If this variable is set, the VIL-Tools do not communicate with the server but instead generate the equivalent FDL code. If the value of the variable is "1", the code is printed on stdout. If the value of the variable is the name of a writable file, the code is written to that file (no locking). A value of "0" is the same as not having the variable defined. See example in $VOVDIR/training/basic/example.csh. |
VOV_FIFO_OPEN | VIL
vovchannel |
VOV_FOREGROUND | vovserver
vovsh GUI |
Sets the foreground color of the VOV dialogs. If not set, the color is chosen
automatically so that each project has a slightly different foreground. The
foreground should be dark. Examples:
VOV_FT_LOGS | vrun | When using vrun (see "indirect taskers") you can choose to propagate the list of log files from FT to NC. This is done by setting VOV_FT_LOGS to 1 in the environment for vrun. |
VOV_GOTOHOST_COMMAND | vovconsole | Command used in the "GoToHost" callback in vovconsole. The command should contain the token '@HOST@' which will be replaced with the name of the host. The default value is "vovxrsh @HOST@". |
VOV_GRABBED_RESOURCES | When a job is being executed on a vovtasker this environment variable is set to describe the resources that have been grabbed for this job. | |
VOV_GROUP | If present, it defines the FairShare group for jobs. | |
VOV_GROUP_PURGE_PERIOD | vovtaskerroot
vovtasker |
Instructs the tasker to periodically purge cached UNIX group information, including gid/name maps and user group lists. Specified in seconds (minimum 60). Default: 0 (disabled). |
VOV_HOST_HTTP_NAME | Variable to control the name of the server as it is to be used in the HTTP interface. If not defined, use VOV_HOST_NAME. | |
VOV_HOST_IP | If present, used to connect to the vovserver. You may want to use this variable
to avoid calling the function getaddrinfo() which can be
expensive on systems in which the DNS is not working properly. Warning: For some values of this variable, the clients will hang indefinitely. The
recommendation, in general, is to not use this variable. The variable overrides
the value of VOV_HOST_NAME. Example:
VOV_HOST_NAME | Used by all tools. It is the name of the machine on which the vovserver is running, unless VOV_HOST_IP is also set, in which case it takes precedence. | |
VOV_HTTP_UNSECURE | vovserver | Disables authentication in the browser. Everyone can connect, but their security level will be READONLY. Used only by vovserver. Its usage is discouraged. Use config(httpSecure) in policy.tcl file instead. |
VOV_INSTANCE_CHARGE_BOUNDARY | vovtasker
vovtaskerroot |
This variable is used mostly for testing, so you don't have to wait for a full hour to test the effect of the other variable VOV_INSTANCE_LAUNCH_TS. If not defined, the CHARGE BOUNDARY is considered to be 3600, which is 1 hour in seconds. The minimum value for this variable is 300 seconds. There is no upper bound. For testing, this variable can be set to lower values, like 300. Recommendation: do not use this variable and accept the default value. |
VOV_INSTANCE_LAUNCH_TS | vovtasker
vovtaskerroot |
Used in cloud computing environments where the charges per instance are rounded
up to the nearest hour. If set, it represents the launch time of the instance. If
the vovtasker/vovtaskerroot uses the option
-z TIMESPEC (e.g. -z 2m) , the idea is to terminate the vovtasker after it has been idle for the specified amount. However, if
the variable VOV_INSTANCE_LAUNCH_TS is set, then the tasker is
kept running if more than 4 minutes away from the hour boundary. This is to avoid
wasting a vovtasker that is essentially already paid for. The
ordinary way to set this variable is in the boot script for an instance using the
value returned, for example, by
vov_ec2_get_launch_time
VOV_INTERACTIVE_AUTH_TIMEOUT | vovtasker | If interactive jobs are failing due to authentication timeouts on the vovtasker, this environment variable can be used to increase the timeout. For example, setenv VOV_INTERACTIVE_AUTH_TIMEOUT 5s will set the authentication timeout used by interactive jobs to 5 seconds. The default is 2s. The value of VOV_INTERACTIVE_AUTH_TIMEOUT is silently restricted between 2s and 30s. It is recommended to use as small a value as feasible since this also blocks the vovtasker from running other jobs. Too long a timeout can also lead to the vovserver marking the vovtasker as sick. |
VOV_INTERACTIVE_PING | nc run -I | For sites that have firewalls that close inactive connections, you can use
this variable to force Accelerator to keep the connection alive
when running in interactive mode (nc -I, etc.). For
example: will send a message
every 20m to the interactive job.The value of VOV_INTERACTIVE_PING is silently limited to a minimum of 1m. |
VOV_JOBCLASS | vw2
vw vov vrt |
If a new job is being added to the trace by direct execution and this variable is set, it will be used as "jobclass" of the job. |
VOV_JOBCLASS_DIRS | nc
FDL vovresourced |
Used to specify jobclass directories in addition to the system ones in vnc.swd/jobclass, \$VOVDIR/local/jobclass and \$VOVDIR/etc/jobclass. Its value is a list of the directories to search for jobclass files. The list elements are separated by colons ':' on UNIX and by semicolons ';' on Windows. |
VOV_JOBCOUNTER | vovcounters
vlmstat vtool |
In the form PORT@HOST,PROJNAME, points to the license emulation server.
Examples:
VOV_JOBCOUNTER_PROJECT | vovcounters | Not used. |
VOV_JOBCOUNTER_VERBOSE | vovcounters | Make vovcounters more verbose. |
VOV_JOBID | When a job is running, it can find its own ID by querying this variable. | |
VOV_JOBNAME | vw2
vw vov vrt |
If a new job is being added to the trace by direct execution and this variable is set, it will be used as "jobname" of the job. |
VOV_JOBPROJ | nc | Used by nc run to define the default value of the jobproj field of a job. The order in which these variables are checked is VOV_JOBPROJ LM_PROJECT RLM_PROJECT and the first one found prevails. |
VOV_JOBSLOT | Set only for jobs running on a tasker. It represents the slot number in which the job is running. | |
VOV_JOB_BLOCKNAME | vovsql_record_one_job | Allows the CAD engineers to define a name for a block. Examples are: CPU, Cache, Sequencer, Decoder, Bus, PCI, DRAM1... If it is not defined, vovsql_record_one_job will also look in the environment for a value from BLOCK. |
VOV_JOB_BLOCKRELEASE | vovsql_record_one_job | Complement/qualifier to VOV_JOB_BLOCKNAME. It allows the CAD engineer to record what specific release of the block is currently being used. For one NAME and one SPIN, there maybe several RELEASEs. |
VOV_JOB_BLOCKSPIN | vovsql_record_one_job | Complement/qualifier to VOV_JOB_BLOCKNAME. It allows the CAD engineer to record what specific spin of the block is being used. One NAME will typically have multiple SPINs. In electronic design, it is usually the floorplan name. |
VOV_JOB_BLOCKVARIANT | vovsql_record_one_job | Complement/qualifier to VOV_JOB_BLOCKNAME. It allows the CAD engineer to record what specific variant of the block is being used. A VARIANT is typically of larger scope than a NAME. One VARIANT will typically have multiple NAMEs. It's like a family or generation of blocks. |
VOV_JOB_EXPERIMENTNAME | vovsql_record_one_job | Define a short name for the experiment in progress. Examples:
congestion_0p60 or congestion_0p65 , or
syn_effort_low , or 16_tracks , etc. If not
defined, the script will look for a common environment variable: NICKNAME. The
experiment name is picked by each designer as they go through their design cycle and
is meaningful mostly to the designer. |
VOV_JOB_EXPERIMENTROOTDIR | vovsql_record_one_job | Define a root directory for the experiment in progress. If not defined, but an experiment config file was found, the location of the experiment config file will be used. |
VOV_JOB_FLOWNAME | vovsql_record_one_job | Allows the CAD engineers to define a name for a flow. Examples are: synthesis, verification, placenoute. |
VOV_JOB_FLOWRELEASE | vovsql_record_one_job | Complement/qualifier to VOV_JOB_FLOWNAME. It allows the CAD engineer to record what specific release of the flow is being used. For one NAME and one SPIN, there maybe several RELEASEs. Examples are: build_78666, rel_1.0, 2012.09... |
VOV_JOB_FLOWSPIN | vovsql_record_one_job | Complement/qualifier to VOV_JOB_FLOWNAME. It allows the CAD engineer to record what specific spin of the flow is being used. One NAME will typically have multiple SPINs. It could be considered as the personality of the flow. Examples are: Q1_stretch... |
VOV_JOB_FLOWVARIANT | vovsql_record_one_job | Complement/qualifier to VOV_JOB_FLOWNAME. It allows the CAD engineer to record what specific variant of the flow is being used. A VARIANT is typically of larger scope than a NAME. One VARIANT will typically have multiple NAMEs. It's like a family of flows. Examples are: FullChip, Block... |
VOV_JOB_NAME | vovsql_record_one_job | Should be set to the name of the job (see the "activity" paragraph in the "recording jobs" page for a discussion on job names). If it is not defined, the jobname defined during the building of the graph will be used, and otherwise an abbreviated command line will be used. |
VOV_JOB_PREDICTIONS_DIR | vovsql_record_one_job | Name of the directory where to generate the memory prediction files. Used by gen_predict_files . |
VOV_JOB_PREDICTNAME | vovsql_record_one_job | Enables invisible override of VOV_JOB_NAME so that a different name can be used for the job just for the matters of memory usage prediction. If it does not exist, the value of VOV_JOB_NAME is used, and if VOV_JOB_NAME does not exist, then the jobname defined during the building of the graph will be used, and if that does not exist, the tool name will be used. |
VOV_JOB_PROJECTNAME | vovsql_record_one_job | Allows the CAD engineers to define a name for a project. Examples are: SandyBridge, IvyBridge, Nehalem, Westmere, Bulldozer, Bobcat, Redwood, Cedar, Krait... If it is not defined, vovsql_record_one_job will also look in the environment for a value from LSB_PROJECT, then LM_PROJECT, then PROJECT. |
VOV_JOB_PROJECTRELEASE | vovsql_record_one_job | Complement/qualifier to VOV_JOB_PROJECTNAME. It allows the CAD engineer to record what specific release of the project is currently being used. For one NAME and one SPIN, there maybe several RELEASEs. Examples are: rel_1.0, nl-2.1, fp10... If it is not defined, vovsql_record_one_job will also look in the environment for a value from RELEASE. |
VOV_JOB_PROJECTSPIN | vovsql_record_one_job | Complement/qualifier to VOV_JOB_PROJECTNAME. It allows the CAD engineer to record what specific spin of the project is being used. One NAME will typically have multiple SPINs. In electronic design, it is usually the tapeout name. Examples are: v1, sa11... If it is not defined, vovsql_record_one_job will also look in the environment for a value from SPIN then TAPEOUT. |
VOV_JOB_PROJECTVARIANT | vovsql_record_one_job | Complement/qualifier to VOV_JOB_PROJECTNAME. It allows the CAD engineer to record what specific variant of the project is being used. A VARIANT is typically of larger scope than a NAME. One VARIANT will typically have multiple NAMEs. It's like a family or generation of projects. Examples are: Evergreen, SouthernIslands, Kepler... If it is not defined, vovsql_record_one_job will also look in the environment for a value from VARIANT. |
VOV_JOB_SITECITY | vovsql_record_one_job | Provide a city name for a site. Some companies use a convention for site names that may not be obvious to a newcomer. Example: LSDC would stand for Lone Star Design Centre. If you're not American, you may not know this means Austin, Texas. The SITECITY field lets you record the name of the city where the site is. Example: Austin. |
VOV_JOB_SITECOUNTRY | vovsql_record_one_job | Records the country of the current site. |
VOV_JOB_SITENAME | vovsql_record_one_job | Provide a site name. This is usually used to record a common disk space / server farm. Examples are: Hyderabad, HYDC, LoneStar, sj, Canada. If it is not defined, vovsql_record_one_job will also look in the environment for a value from SITE, then XSITE. |
VOV_JOB_SITETIMEZONE | vovsql_record_one_job | Records the timezone of the current site. |
VOV_JOB_USERSITENAME | vovsql_record_one_job | User site vs host site. With global companies, a user located in Hyderabad,
India may be working remotely on a server farm located in Anchorage, Alaska, USA.
Due to the hierarchy of the company, you may want to capture the difference between
the site where the user is physically located (Hyderabad) as (s)he may report
through a local hierarchy, and the site where the job is running (Anchorage) as this
cost depends from the American hierarchy. Depending on their level in the
organization, some persons may be interested in activity reports based on people's
locations (such as, what are my people in Hyderabad doing), while others may be
interested in how is the Anchorage farm doing. The best way to address this is to use a background data acquisition script that populates/refreshes the users' sites everyday from a central location like LDAP or Microsoft ActiveDirectory, and to let the environment variables take care of the job/compute host's site. VOV_JOB_USERSITENAME can provide a different site name just for the user. This is usually used to record the physical location of the human running the jobs. Examples are: Hyderabad, HYDC, LoneStar, sj, Canada. If it is not defined, vovsql_record_one_job will also look in the environment for a value from VOV_JOB_SITENAME, then SITE, then XSITE. |
VOV_LICENSE_KEY | vovserver
vovreadlicutil |
Specify a path for the VOV License Key file. The default is license.key in the PROJECT.swd directory. |
VOV_LICMON | ftlm_lmproject | Register job project information. It is used to point to the instance of
Monitor that captures checkout information. It has the following forms:
VOV_LIMIT_cputime | vw
vovtasker |
Together with other VOV_LIMIT_* variables, allows passing of 'limit'
information to a job using the environment. This one controls the "cputime" limit.
Common use in
Accelerator:
VOV_LIMIT_datasize | vw
vovtasker |
information to a job using the environment. Common use in
Accelerator:
The value of the variable can be an integer followed by a unit indicator. The
recognized unit indicators are:
VOV_LIMIT_descriptors | vw
vovtasker |
Do not use this variable. Use VOV_LIMIT_openfiles instead. |
VOV_LIMIT_filesize | vw
vovtasker |
Accelerator:
On Linux, this limit controls the system limit called RLIMIT_FSIZE. The
VOV_LIMIT_maxproc | vw
vovtasker |
information to a job using the environment. Common use in Accelerator:
On Linux, this limit controls the system limit called RLIMIT_NPROC. The value of the variable must be an integer. |
VOV_LIMIT_memorylocked | vw
vovtasker |
On Linux, this limit controls the system limit called RLIMIT_MEMLOCK. The
VOV_LIMIT_memoryuse | vw
vovtasker |
This variable is a no-op and is provided for backward compatibility only. The same is true for the memoryuse limit in UNIX shells as well. |
VOV_LIMIT_openfiles | vw
vovtasker |
information to a job using the environment. This one controls the number of file
descriptors that can be used by a job. Common use in Accelerator:
In C-shell, this limit is also called 'descriptors'. |
VOV_LIMIT_stacksize | vw
vovtasker |
VOV_LIMIT_vmemoryuse | vw
vovtasker |
Together with other VOV_LIMIT_* variables, is used to pass shell 'limit'
information to a job via the environment. Common use in
Accelerator:
On Linux, this limit controls the system limit called RLIMIT_AS (address space). The value of the variable must be an sequence of digits followed by an
optional unit indicator letter (case insensitive), or the string value
'unlimited'. If there is no unit indicator, the units are kilobytes (1024 bytes).
The recognized unit indicators are:
VOV_LMPROJECT_EXPIRE | ftlm_lmproject | When set, this overrides the default 4h expiration of the management project designation entered by the ftlm_lmproject script. The value is a VOV timespec, e.g. 7d is seven days. |
VOV_LM_BATCH | ftlm_batch_report | Affects the generation of HTML for batch reports. In particular, if the variable is set (to any value), it disables the INPUT on images. |
VOV_LM_VARNAMES | vw | Specify a comma-separated list of variables to be set automatically on the basis of the grabbed resources. This variable is honored by the VOV wrappers (vw, vov, ...) so jobs that use no wrapper (like interactive jobs) do not have access to this service. An alternative method to set the LM_LICENSE_FILE automatically is provided by the utility vovgetflexlmdaemons. |
VOV_LOCAL_DIR | vovworkflowsim | A local directory on the machine that can be used for I/O intensive operations. This is used by vovworkflowsim to store the intermediate results of the simulation. In that context, the default value of the directory is /tmp/vov/wa. |
VOV_LOG_LSFEMUL | bsub bjob bkill lsid lshosts bqueues bmgroup |
Choose file to be used to log the invocations of the LSF emulation scripts.
Example: setenv VOV_LOG_LSFEMUL ~/lsfemul.log |
VOV_LSF_QUEUES | vsm nc mon |
Only needed when using indirect taskers from VOV to LSF. It represents a space-separated list of LSF queues to be monitored. |
VOV_MAX_WAIT_AFTER_CRASH | vovtaskerroot
vovtasker |
Deprecated. Please use VOV_MAX_WAIT_TO_RECONNECT instead. |
VOV_MAX_WAIT_NO_START | vovtaskerroot
vovtasker |
Controls the time a tasker waits for
fork()/exec() to work. This is called the "time to start" and
it is typically a few milliseconds, but could grow large or infinite if there are
problems with the machines. The valid range is 20 seconds to 8 days. The default
value is 1 minute. This value may be a VOV timespec, e.g. 5m (5 minutes). This
variable must be set when vovtasker starts, usually by setting
it in the project SWD/setup.tcl file. The value may be changed
at runtime with vovtaskermgr configure
TASKERNAME maxwaitnostart TIMESPEC . |
VOV_MAX_WAIT_TO_RECONNECT | vovtaskerroot
vovtasker |
Controls the time a tasker waits for a new vovserver to appear after losing connection to the server. The default value is 3 minutes for FlowTracer and 4 days for all other products. This variable must be set when the tasker starts. |
VOV_MD5_CMD |
vw vov vrt vw2 |
Change the command used to compute the md5 digest for purpose of computing MD5
based barriers. The default is /sbin/md5 -q on MacOsX and
/usr/bin/md5sum on the other platforms. |
VOV_MIN_DESCRIPTORS | ncmgr
wxmgr |
Specify the minimum number of file descriptors to be required by the server. The shell in which the server is being started will be tested, and if the current file descriptor soft limit is less than the specified minimum, an attempt will be made to raise the limit. If the specified minimum exceeds the system's file descriptor hard limit, an error will be displayed and the server will not be started. If not specified, the value used is 2500. |
VOV_NAME_SERVICE_RETRY_MAX | vovserver
vovtasker |
Number of attempts the tasker will make to determine the current username via local name services. Retries may be necessitated by misconfigured or malfunctioning name services on the host. The default value is 3. |
VOV_NAME_SERVICE_RETRY_WAIT | vovserver
vovtasker |
Number of seconds to wait between retries when querying the name services for the current username. Retries may be necessitated by misconfigured or malfunctioning name services on the host. The default value is 3. |
VOV_NISRETRYCT | vovtasker | In systems where NIS is slow or unreliable, this variable controls how many times the getgrnam() call should be retried (default 5s). Its use is discouraged: fix NIS instead. |
VOV_NISRETRYWAIT | vovtasker | In systems where NIS is slow or unreliable, this variable controls how long to wait bewteen retries (default 10s). Its use is discouraged: fix NIS instead. |
VOV_PAUSE_CHILD_SIGNAL | vovtasker | Linux platforms only Controls the signal sent to child processes when a tasker enters the PAUSED state. By default, this signal will be SIGSTOP. If an unsupported value is entered, the variable will be ignored and the default behavior ("STOP") will occur. Supported values:
Examples:
VOV_PBS_JOB_HISTORY_ENABLE | qdel | Direct the PBS emulation environment to behave as though job history were enabled. User must set the value of this variable to an integer greater than zero to enable this behavior. Default is disabled. |
VOV_PIPES_TO_CLOSE | VIL
vovchannel |
Used internally by VIL on Windows and by vovchannel. Should not be set by the user. |
VOV_PORT_NUMBER | vovserver
vovtasker vovsh |
Controls the port number to which vovserver will bind. The port is used by
various clients to establish a connection with the server. The variable can have the
following forms:
VOV_PROJECT_NAME | Used by all tools. Name of the project managed by a vovserver. | |
VOV_PROJECT_TYPES_DIR | The primary directory where one can find the definition of project types. The default directories that are always searched are: $VOVDIR/local/ProjectTypes and $VOVDIR/etc/ProjectTypes . | |
VOV_PROTOCOL | ALL | Control the communication protocol between clients and server. The default value is "8.2". Legal values are either "8.2" or "8.3", but any value other than "8.2" is interpreted as "8.3" at this time. Introduced in 8.2.5, mostly for testing. Customers should not set this variable. |
VOV_RAM_SENTRY | vovtaskerroot
vovtasker |
Enables the RAM Sentry, a mechanism that monitors jobs' memory utilization and prevents them from forcing a tasker to enter swap. Set this variable to 1 in the NC setup.tcl file to enable the RAM Sentry. |
VOV_READONLY_PORT_NUMBER | vovserver | Controls the port number to which vovserver will bind for guest access to the
web UI. The variable can have the following forms:
VOV_REGISTRY | vovproject
vovserver |
Used to point at the VOV Registry directory. By default, this is $VOVDIR/local/registry. |
VOV_RELIABLE_TIMEOUT | vovsh
vovtasker |
This variable controls how long the software waits for the server to appear or to reappear after a crash. The value is a "time specification". The default is 3 seconds for the first connection and 0 seconds for reconnection after a crash. |
VOV_RESOURCES | vw vw2 vov vrt |
If a new job is being added to the trace by direct execution and this variable is set, it will be used as resources of the job. |
VOV_RETRACE_FAST | vw vrt vtrace vw2 vov |
Used to indicate to the tools that a fast retracing has been requested, meaning that the dependencies should not be computed. The value of the variable is irrelevant. This variable is set by vw. The user should not be concerned about this variable. |
VOV_RETRY_CHDIR | vovtasker | Control how many times the tasker needs to try chdir() to the working directory of the job. Normally, the chdir() is quite fast. On some systems, the chdir() may fail for a variety of reasons, including automount failure, NFS caching delays. The default value is 1, the range is from 0 to 100, which is silently enforced. |
VOV_RETRY_CHDIR_SLEEP | vovtasker | Controls the time interval between successive attempts to try chdir() to the working directory of the job. The default value is 1, the range is from 0 to 100, which is silently enforced. |
VOV_RETRY_CHDIR_SLEEP_BACKOFF | vovtasker | A factor that scales the VOV_RETRY_CHDIR_SLEEP amount between successive attempts to try chdir() to the working directory of the job. See also VOV_RETRY_CHDIR and VOV_RETRY_CHDIR_SLEEP. The default value is 1.0 and must be 1.0 or greater and is silently enforced. |
VOV_RLM_USE_CPUS | vovinfo vovtaskerroot vovtasker |
Used to force the vovtasker to use the
cpu_* features instead of the host_* features.
If the similar variable VOV_RLM_USE_HOSTS is also defined, it takes precedence over
this. Set it to 1 (or any value) to activate. Unset the variable to disable. |
VOV_RLM_USE_HOSTS | vovinfo vovtaskerroot vovtasker |
host_* features instead of the cpu_* features.
This variable takes precedence over the similar VOV_RLM_USE_CPUS. Set it to 1 (or
VOV_RSH_COMMAND | vovtaskermgr | Command used in vovtaskermgr to start taskers. |
VOV_SERVER_EXE | vovproject | Name to the vovserver binary. Defaults to vovserver. Normally used during testing. |
VOV_SHOW_SERVICE_TIME | vovsh vovtasker vovbuild |
Used only on the client side. The vovserver always sends back to the client the
"cost" in milliseconds of each service performed on behalf of the client. If set,
its value represent the threshold at which the expensive services are reported using
stdout. This variable is useful to educate the user about the impact of each client
call on the vovserver. If the variable is missing or it has a non-positive value,
the showing is disabled. Otherwise the value is capped to 1000ms. Example:
VOV_SH_NOCONNECT | Tell vovsh to not connect to the server. Use option -n instead. | |
VOV_SKIP_SERVER_LOCK | vovserver | Use if locking is disabled or not working in the filesystem containing the directory where you want to run a vovserver. To be effective, you have to set this variable to 1 before starting vovserver. Use with care. You must be absolutely sure that there is no other vovserver running in the same directory. |
VOV_TASKER_LOADAVG | vovtasker
vovtaskerroot |
When computing the load on a machine, vovtasker normally uses the largest of the 1m and 5m loads. If this variable is set to any value, then the machine load will simply be the 1m load. Implemented because of user request. Our recommendation is to not use this variable. |
VOV_TASKER_NAME | When a job is running in a tasker, this variable specifies the name of the tasker. | |
VOV_TASKER_PROCLIST_FLAGS | vovtasker
vovtaskerroot |
Linux platforms only Flags to control how to assign processes to a job. There are three flags:
As of version 2019.01u4, the default value is 0x7 (i.e. all flags are on). Previously, the default value was 0x1. |
VOV_TASKER_SID_DISABLE | vovtasker
vovtaskerroot |
Linux platforms only Possible values are 0 and 1; default is 0. Signifies that the tasker should not create a new Linux session for itself and its child processes. |
VOV_SQ3_DIR | The default directory for the SQLite databases is sq3 in the server working directory (e.g. vnc.swd/sq3/.) This variable allows the user to change the directory. This is useful if the default directory is not in a local file-system. | |
VOV_STAGING_DIR | vovserver | The staging of files is allowed only from a specific directory visible by vovserver. This directory is normally PROJECT.swd/staging but this can be changed by using the variable VOV_STAGING_DIR. |
VOV_STDOUT_SPEC | vw vrt vov vtrace vw2 |
Control the names of files used to save stdout and stderr. The value is
computed by substituting the substrings @OUT@ and @UNIQUE@ and @ID@. Examples:
VOV_STOP_SIGNALS | nc stop
bkill |
Example:
In the case of nc stop, instead of this environment variable, one can use a property on a job with the name STOP_SIGNALS and with the same syntax. The signals are sent to the job with a delay determined by VOV_STOP_SIGNAL_DELAY, which by default is 3 second. A property on a job STOP_SIGNAL_DELAY can be used as well. If both property and env exist, the property is honored. If both NC_STOP_SIGNALS and VOV_STOP_SIGNALS are present in the environment, the value of VOV_STOP_SIGNALS will be used. If both NC_STOP_SIG_DELAY and VOV_STOP_SIGNAL_DELAY are present in the environment, the value of VOV_STOP_SIGNAL_DELAY will be used. |
VOV_STOP_SIGNAL_DELAY | nc stop
bkill |
Specify the delay between signals sent by nc stop. In seconds. The default value is 3 second. If both NC_STOP_SIG_DELAY and VOV_STOP_SIGNAL_DELAY are present in the environment, the value of VOV_STOP_SIGNAL_DELAY will be used. |
VOV_STRICT_TRACING | vw vrt vov vtrace |
By default, FlowTracer does not trace the files specified by file in the exclude file (exclude.tcl) in the server working directory. If this variable is set then all files will be traced. |
VOV_SUSPEND_SIGNALS | vtk_job_control | Specify the signals sent by vtk_job_control when action is
SUSPEND This is a comma-separated list of signals to be sent to the processes in the job. The signals include TERM INT KILL HUP USR1 USR2 CONT TSTP. In
addition, EXT is supported as a signal in the format
EXT:SIGNAL:INCLUDERX:EXCLUDERX:SKIPTOP (notice that we use the colon ':' instead
of ',' commas).
Exmple:
A
The signals are sent to the job with a delay determined by |
VOV_SWD_KEY | nc
ncmgr |
This variable is used in the routines to find the server working directory.
There are possibly many mappings for the server working directory, which you can
find with vovserverdir -m . To add a new mapping, use vtk_swd_set in the policy.tcl file. The default for this variable is "unix" on UNIX systems and "windows" on Windows systems. If the value of this variable is "none", then the client will run without access to the SWD directory. This is often used with VOVEQUIV_CACHE_FILE=vovcache |
VOV_SYNC_CACHE_DIR | Point to a colon-separated list of cache directories in DesignSync (formerly
by Synchronicity, then Enovia, now Dassault) Set to the canonical full path to the
cache directory. If set, all links into the cache are NOT expanded. The recommended
way to set this variable is with vovequiv -p. Do not use:
but rather use:
You can use VOV_DEBUG_SYMLINKS to check the behavior of this variable. |
VOV_TIME_TOLERANCE | vw
vov vrt |
When the wrapper vw, vov, vrt checks the timestamp of its outputs, compare the start time of the job and the timestamp allowing for the specified tolerance. The default value is 0 (zero) and the range is between 0 and 600 (10 minutes). The value must be an integer. Typical values are 2 or 3. This accounts for time differences between the machines where the job is running and the filesystem. If this variable is missing, the default value is the same as the config(timeTolerance) in policy.tcl Starting from 2013.09, the recommendation is to not use this variable. |
VOV_UMASK | vw
vov vrt |
Used to control umask inside a wrapper, it controls the
permissions on the files created by the wrappers, such as the stdout and stderr
logs. This takes any value allowed for umask.
VOV_UNSET_VARNAMES | vw | Specify a comma-separated list of variables to be unset in the job execution environment. This is normally used in conjunction with VOV_LM_VARNAMES so that license variables are cleaned before being augmented by Accelerator. This variable is honored by the VOV wrappers (vw, vov, ...) so jobs that use no wrapper (like interactive jobs) do not have access to this service. |
VOV_USE_COMMAS_IN_MAPS | vovlanc vovlavtkncset |
This variable controls how the complex maps created by Allocator are defined on the Accelerator side. By default, if a resource map License:a maps to two components like License:a1 and License:a2, then LA defines the map as "License:a1 OR License:a2". If the variable VOV_USE_COMMAS_IN_MAPS is set to a non-zero value, then the map will be defined as "License:a1,License:a2" which is more efficient to manage in the scheduler. |
VOV_USE_INITGROUPS | vovtaskerroot | Used on UNIX by vovtaskerroot to decide the method to use to switch a user identity and to initialize the groups. If set to a non-null value, the tasker uses initgroups() to initialize the groups. This call may add some load to the NIS information system. By default, vovtaskerroot caches the groups information for a user and uses a more economical call to setgroups() to initialize the groups. Use of this variable is recommended for the sites that have complicated setup of groups. |
VOV_USE_PS | vovps vovtaskerroot vovtasker |
Used by the routine that scans the process table. Useful on some Solaris
platforms where traversing the /proc/* filesytem may freeze
the code (even using ls /proc/pid freezes). Use this
variable to disable the code that scans the /proc filesytem and
revert to a method based on running ps. This is only a bit
slower. Use vovps -a to see if you need to set the variable. If the
command freezes, then set VOV_USE_PS and try again. Also, you may want to try to use
truss vovps -a to see which PID is causing the trouble. The same
behavior is obtained with the option -P of
vovps. |
VOV_USE_VEP | std.vov.aliases
std.vov.aliases.sh |
Used by Altair Accelerator Products setup scripts. Controls whether the 'vep' command is active. This command sets the prompt to show the Altair Accelerator Products project and environment. If unset or set to a non-zero value, the vep command will be active as an alias for csh/tcsh or a shell function for sh/ksh/bash. Set VOV_USE_VEP to 0 before sourcing your .vovrc file to disable vep. The alias still exists, but is set to do nothing. |
VOV_USE_VOVGETGROUPS | vovtaskerroot | Used on UNIX-based systems by vovtaskerroot. By default, instead of directly calling the getgrnam() POSIX API function, which has been shown to hang randomly and indefinitely on some systems (e.g. Linux with LDAP), the tasker will call the external utility vovgetgroups to find the list of groups to which a user belongs. This variable provides 2 types of control over this behavior: Set to 0 to disable the use of the external vovgetgroups utility and force the tasker to call getgrnam() directly. Set to 2 to continue to use the external utility, but instruct the utility to call the getgrent() POSIX API function instead of the default call to getgrouplist(). This is mainly for debugging purposes, since this mode of operation results in slower processing of group information. |
VOV_USE_WAITNOHANG | vovtasker
vovtaskerroot |
Normally the vovtasker waits for the job with a simple waitpid(pid,,NULLFLAGS) command which means that the waitpid() returns as soon as the status of the process pid is available. We have noticed on Solaris that the waitpid() call can hang even if the process status is available. In such cases, it is possible to set VOV_USE_WAITNOHANG to change the wait into a loop which has been shown to be effective in avoiding the hanging. For maximum performance, do not use this variable. |
VOV_VW_CHECK_UPCONE | vw vov vrt vw2 |
setenv VOV_VW_CHECK_UPCONE 1
If set to 1, tells the Vov wrappers to check the timestamp of the files in the upcone of the job. This is useful if your organization allows editing of intermediate files. This is equivalent to using the option -u in vw (or vov, vrt, vw2). |
VOV_VW_ENTERPRISE | vw vov vrt vw2 |
When the environment variable VOV_VW_ENTERPRISE is defined, each job wrapper -
vov, vw, vrt,
vw2 - will look for two scripts in $VOV_VW_ENTERPRISE_DIR or
$VOVDIR/local/ProjectTypes/ftenterprise/db/
Those scripts can be written in bourne shell, cshell, tcl or any other language. |
VOV_VW_ENTERPRISE_DIR | vw vov vrt vw2 |
Used in conjunction when the environment variable VOV_VW_ENTERPRISE is
defined. Use VOV_VW_ENTERPRISE_DIR to define a location where to find:
If this variable is not defined, the location $VOVDIR/local/ProjectTypes/ftenterprise/db/ will be used instead. |
VOV_VW_EXE_DB | vw vov vrt vw2 |
Choose the database (DB) of the executables used to run the command. The normal value is "FILE" and other meaningful values are "FILEX", "PHANTOM". If you specify another value, e.g. "NONE", then the executable will not be added to the input dependencies of the job. The default value is "FILE". |
VOV_VW_LICMON | vw vov vrt vw2 |
If this variable is set, then the wrappers react to VOV_LICMON by calling ftlm_lmproject. If the variable is not set, then only the vovtasker reacts to VOV_LICMON. |
VOV_VW_LOGNAME | vw vov vrt vw2 |
Choose the name of the logfile used for verbose output. The default has the form .vw2_PID_verbose.out |
VOV_VW_NFS_PROTECTION | vw vov vrt vw2 |
setenv VOV_VW_NFS_PROTECTION 1
This is equivalent to the option -n in vw. If set to 1, tell Vov wrappers to activate the protection (retry up to 60 seconds at 5 seconds intervals) against dirty NFS caches. You can find that a particular job has needed that protection by looking for a NFS_PROTECTION property attached to the job. |
VOV_VW_NFS_WAIT | vw vov vrt vw2 |
This variable controls the wait time for the NFS protection mechanism. The
acceptable range is between 10s and 1h. The default value is 1m.
Example:
VOV_VW_PAUSE_ON_TSTP | vw | Determines whether to pause vw jobs when they receive a
SIGTSTP signal. Possible values are 0 and 1; default is 0. If set to 1,
vw jobs will be paused when they receive a SIGTSTP signal and
continue when receiving either a SIGCONT or SIGALRM signal.
Example:
VOV_VW_PING | vw vov vrt vw2 |
For sites that have nasty firewalls that close inactive connections, you can
use this variable to force vw to keep the connection alive. For example,
will send a message ('ping') every 20m
The default is 20m. The value of VOV_VW_PING is silently restricted between 3s and
10d. This function is disabled by setting VOV_VW_PING to 0. A good place to set this
variable is the setup.tcl file. |
VOV_VW_RETRY_WHICH | vw | Control how many times the wrapper will try to verify the existence of a job's command. This is mainly useful when submission scripts are used that generate a job script, and that script is located on an NFS file share that often experiences delays. The default value is 0 (try once, no retries), the range is from 0 to 100, which is silently enforced. |
VOV_VW_RETRY_WHICH_SLEEP | vw | Controls the time interval (in seconds) between successive attempts to verify the existence a job's command. The default value is 1, the range is from 1 to 100, which is silently enforced. |
VOV_VW_RETRY_WHICH_SLEEP_BACKOFF | vw | A factor that scales the VOV_VW_RETRY_WHICH_SLEEP amount between successive attempts to try verify a job's command. The default value is 1.0, the range is from 1.0 to 10.0, which is silently enforced. |
VOV_VW_SIG_IGN | vw vov vrt vw2 |
Tell Vov wrappers to ignore most signals. Same behavior as option -s. |
VOV_VW_TRACK_LINKS | vw vov vrt vw2 |
Tell Vov wrappers to track all symbolic links used in path expansion. |
VOV_VW_VERBOSE | vw vov vrt vw2 |
Make Vov wrappers verbose. Same as -v. Use values from 0 to 4. |
VOV_WEB_PORT_NUMBER | vovserver | Controls the port number to which vovserver will bind for guest access to the
VOV_WX_STUCK_VOVWXD_AGE | live_wx_check_vovwxd_daemon.tcl | Age at which the vovwxd daemon should be considered as stuck
and an alert should be generated. Set in wx.swd/setup.tcl. Age can be in timespec or seconds format. |
VOV_WX_STUCK_VOVWXD_RESTART | live_wx_check_vovwxd_daemon.tcl | If set to 1, the vovwxd daemon will be restarted if the
stuck age has been exceeded. Set in wx.swd/setup.tcl. |
VOV_WX_STUCK_VOVWXD_ALERT_AGE | live_wx_check_vovwxd_daemon.tcl | If set to 1, the vovwxd daemon will be straced if the stuck
Note: Both the
timeout and strace commands must be on the system path for this functionality to
be enabled.
VOV_XYNT_STOP_CMD | XYNTService.exe | Note: This is no longer needed. Use "single-file" packages instead.
If
set, this variable specifies the command that is to be used by
XYNTService.exe to stop a service. The command will be
concatenated with a space and the PID of the top process to be stopped. Typical
values are: TASKKILL.EXE /F /T /PID , TSKILL.EXE
WX_NOCLEAN_CMDFILE_LINES | wxrun | Performance optimization for Accelerator Plus job submissions. Setting to 1 will disable line cleaning in wxrun when using a command file (-f). Doing so puts the burden of making sure the command file has clean line endings and appropriately escaped characters, when needed. |
WX_PREJOB_PER_TASKER | bsub | Performance optimization for Accelerator Plus job submissions using the LSF
bsub emulation utility. Setting to 1 will change the behavior of specifying a pre-job in such a way that it is done on a per-tasker basis instead of a per-job basis. This is beneficial when the pre-job is used to validate that a host is appropriate for a job and no per-job functionality is being performed. |
