Set Feature Capacity
Monitor tracks the capacity of licenses in addition to utilization data. This is done so automatically with a periodic job, via the SNAPSHOT_CAPACITY task by loading a snapshot of the capacity of all features every hour by default, comparing the values against what is in the database and if they differ, inserting a new capacity value for each feature. In parallel, a data file also maintains a history of the capacity changes. This data file is useful for multi-site situations to aggregate capacity data to a parent site.
- Show existing capacity values
- Reload capacity values
- Set capacity value for a specific feature for a specific time
Operation
To execute ftlm_capacity, first setup the CLI:
% vovproject enable licmon
ftlm_capacity: Usage Message
Manages feature capacity information in the LicenseMonitor database.
SYNOPSIS:
% ftlm_capacity <ACTION> [OPTIONS]
ACTIONS:
show -- Show latest capacity information.
dump -- Same as show, only with Unix timestamps.
clear -- Clear capacity data from database.
checkmismatch -- Check mismatch between latest DB capacity and live
data. Requires a tag to be specified with -tag.
fixmismatch -- Fix mismatches that are found with checkmismatch.
load -- Load information about capacity by parsing the
resources logs (in licmon.swd/logs/resources*)
snapshot -- Snapshot capacity info using current information.
snapfromfile <FILE> -- Load snapshot capacity info from file. This action
does not work with the tag/feature/start/finish
options below.
Format of the file: setCapacity TAG FEATURE
TOKENS TIMESTAMP
set <TAG> <FEATURE> <TOKENS> <DATE_SPEC>
-- Set a new data point in the capacity table.
setforward <TAG> <FEATURE> <TOKENS> <DATE_SPEC>
-- Same as 'set' but delete all points where the
timestamp is greater than the specified timestamp.
OPTIONS:
-v -- Increase verbosity.
-all -- For show and dump, display all capacities as
opposed to the latest only.
-n -- Dry-run mode for write operations.
-tag <TAG> -- Constrain to a specific tag.
-feature <FEATURE> -- Constrain to a specific feature.
-start <DATESPEC> -- Specify start for load, show, and dump actions.
-finish <DATESPEC> -- Specify finish for load, show, and dump actions.
-srcdir <DIR> -- Directory with the resources*log files.
Default: *.swd/logs
-wavedir <DIR> -- Directory where waves should be stored.
Default: *.swd/logs/waves
-force -- Prevent redundant point detection for
snapfromfile action.
EXAMPLES:
% ftlm_capacity show
% ftlm_capacity dump
% ftlm_capacity show -feature hspice
% ftlm_capacity dump -tag EDA -feature hspice -start 20090215
% ftlm_capacity load
% ftlm_capacity load -tag EDA
% ftlm_capacity set EDA hspice 12 "1 year ago"
% ftlm_capacity setforward EDA hspice 12 "1 year ago"
% ftlm_capacity clear -tag EDA
% ftlm_capacity snapshot
% ftlm_capacity snapfromfile licmon.swd/data/capacity/2011.01.01.cap
