Checkouts Page
The Current Checkouts page shows all checkouts for all tags and features at the time the page was loaded. The checkouts are sorted by their age in descending order by default. This order helps to identify problematic checkouts that may require attention.
Simple View
Each row in the table shows one license checkout.
Figure 1. Simple View
- Tag
- The tag representing the license server.
- Feature
- The license feature name. If the feature name begins with "T:", the feature is a subfeature, which is activated when certain token-based features are checked out. Note that subfeatures are supported on an inclusive basis only. See the Features Page for details.
- User
- The user holding the checkout. If the user begins with "r:", a license reservation is in effect for the user or group indicated.
- LDAP
- If the LDAP interface has been configured by the Monitor administrator, the folder icon can be clicked to obtain user pre-configured attributes from LDAP such as phone number, department, or location.
- The email icon is a mailto link that can be used to send an email to all users of the feature using the client machine's configured email client. The client must be capable of handling mailto links.
- Host
- The host on which the job holding the feature is running.
- Project
- The project assignment for the current checkout.
- Tokens
- The actual number of licenses.
- Age
- The age of the checkout. This is useful for finding features held by abandoned or neglected tool sessions. For FlexNet Publisher, the age used in this column is the age reported by lmstat. For the observed age, which is the age at which Monitor first detected the checkout, use the "Complete View".
- Graphs
- Contains shortcut icons for generating plots and heatmaps.
- Remove
- If the user that is logged in matches that of the checkout, or the user has an administrator security principle, the trash can icon can be used to perform the removal of the checkout. Removal of checkouts can only occur once the age of the checkout is at least two minutes.
Complete View
Figure 2. Checkouts Complete View
- Capacity
- The capacity of the feature that is checked out. If the capacity shown includes a number inside of parentheses, the checkout is one that utilizes multiple tokens and the enclosed number represents the calculated capacity based upon the number of tokens checked out. For example, if a feature has 100 tokens available and the checkout is using 10 tokens, the calculated capacity would also be 10 (100/10=10).
- Display
- Shows either the value of the display field from the license server status command.
- Handle
- The license manager handle for the checkout.
- Version
- The version reported by the tool that has been checked out.
- PID
- The PID of the process which has that token checked out. This is currenly only supported for Cadence and Synopsis.
- PS
- A link to get process statistics for the host where the checkout is held. This functionality requires the network monitoring capability of Monitor to be configured for the host for which the license checkout exists.
- Reported
- The time which has passed since the first checkout was reported by lmstat.
- Observed Age
- The age at which Monitor first detected the checkout. This is helpful in cases where FlexNet Publisher's lmstat utility reports false checkout times. This is the age that is stored in the Monitor database and used for historical reporting.
- Linger
- This indicates the time that the checkout will be checked in unless the tool renews it.
- HostIdle
- Some users want to use the information about keyboard and mouse activity on a host to determine the status of the license handles checked-out on that host. Specifically, if the keyboard and mouse are idle, then the handles are also to be considered idle, and they can possibly be removed.
- Graphs
- Links to graphical representations of the data.
