Set Up My Views
To set up your own view, perform the following steps:
  1. From the Views tab, select the My View option.
    Figure 1. My View
  2. Enter a name for your view and click Create New View.
    A new window displays.
    Figure 2. View Editor
  3. Enter a filter name and then select from Tags or Features list.
    For example:
    • Filter Name: Enter a filter name.
    • Tags: Enter an actual tag name, such as BUILT_IN or a tag pattern (or a tag pattern match).
    • Features: Enter a feature, such as AEMv8_RAVEN. For pattern matches, both the ? (single character match) and * (multiple character match) wildcard characters are supported.
  4. Repeat this process until you have defined as many filters as you like.
  5. When done, click Finished Editing.
    You will then see the All View page.
  6. To set your new view as the default view, click Set as Default.
