Updated Data from License Servers is not being Received
- The vovlmd daemon must be running to schedule the jobs. Check it via the page.
- Check that the parser slave is running via the Tasker page.
- Go to http://localhost:5555/admin.
- Scroll down to the Project Configuration Files section, click on Slaves file link.
- Check that the load average on the system is not too high.
- The default parser tasker has four job slots and a maxload of 10.0.
- If the load average is too high, the parser will halt the execution of new jobs until the load average drops below the maxload value.
- Try to prevent other CPU-intensive processes from running on the same machine.
- Check the output of the most recent parsing job.
- Go to the Current tab and select the Raw Data tab.
- Or, go to the licmon.swd/vovlmd directory to see if the status command is having problems executing.
