Start Monitor
After downloading Monitor, right-click on the executable
file and select Run as administrator.
The following window will display:
Figure 1. Altair Monitor Windows -
Make changes to the directories as desired.
Note: Windows users, be sure to use forward slashes and NOT back slashes.
When done, click Start.
The extraction may take time some time. When Monitor is started, you will see “Altair Monitor running as process …” at the bottom of the window.
- With Monitor running, open a web browser and go to http://localhost:5555 and login. Use the same login you use on your home computer.
- Continue with the setup process.
