Alerts for a License Server being Monitored are Intermittently Thrown
Status command failures are common, due to network connectivity glitches, bugs in the license server status command, or other external influences. Since Monitor keeps the most recent parsing job output only by default, this log cannot be used to track down the root cause of intermittent failures. But there is an advanced debug feature available to keep an archive of all parsing.
To enable this feature, go to the Admin tab and select the Daemons option.
Figure 1. vovtriggerd
