Resource Path
BASE_URL + "/api/" + VERSION + "/" + REST
BASE_URL
is the initial part of the URL for the Accelerator queue to access. For example, if the Accelerator
NC_QUEUE
environment variable was set to My_Test_Queue
, then use the
nc cmd vovbrowser command to obtain a BASE_URL.
The VERSION is the REST API version, currently v3.
REST is the remaining part of the URL that applies to the specific types of objects you will be referencing.
https://server.domain.myco.com:6330/api/v3/project/1/version
HTTP Verb
- POST
- Creates a resource
- GET
- Retrieves one or more resources
- PUT
- Updates or controls a resource
- PATCH
- Updates a resource
- DELETE
- Deletes a resource
Body
The body of a REST request defines parameters and options that apply to the action being taken. A POST or PUT request has a body. A GET or DELETE request has no body. A Python dictionary data structure is the usual format for the body, and it consists of a set of keywords with associated values.
Header
The header contains metadata about the message being sent to the server which includes, importantly, an access token. REST HTTP requests are initiated across the network from a node other than the one on which the Accelerator server is running. The access token provides the assurance that the sender has permission to request the REST action on the server.
An authentication request type is available via a POST that supplies a username and password to the server, to which the server responds with the access token. When a REST request comes in later with this access token, the server can quickly and reliably extract the user identity and permissions as a prelude to processing the request. Accelerator REST utilizes a style of access token known as JSON Web Tokens (JWTs).
