Example Application: REST 101
1 #!/usr/bin/python
2 #
3 # nc_rest_101.py
4 #
5 import os, sys, string, requests, json
6 from getToken import getJWT, getMyPassword
7
8 url= os.environ['NC_URL']
9 jwt = getJWT( url, os.environ['USER'], getMyPassword())
10 query = url + '/api/v3/project/1/project'
11 r = requests.get(query, headers={'Authorization': jwt})
12 print ( json.dumps(r.json(),indent=2))
- Line 6 imports the getToken.py module. See getToken.py source code in a later section of this tutorial.
- Line 9 requests the access token, a JWT, from the server. This token identifies the current user and authenticates and authorizes REST requests until the token expires.
- Line 10 shows how to assemble the right URL for the query from the REST API name space.
- Line 11 shows how to generate the correct HTTP GET request that transmits the REST API request.
- Line 12 pretty-prints the JSON response returned from the server.
Before you run this program or other examples that call getJWT(), create the getToken.py module in the same directory using the source code found in the “JWT Token Allocation” section later in this tutorial.
% echo $NC_QUEUE
MY_NC_QUEUE
% export NC_URL="`nc cmd vovbrowser`"
% echo $NC_URL
http://ncserverhost.domain.myco.com:10574
% python nc_rest_101.py
Password:
"rows": [
"MY_NC_QUEUE"
"errormsg": "",
"startrow": 1,
"query": "SELECT project FROM 1",
"columns": [
"field": "PROJECT",
"col": 0
"endrow": 1
Example Applications: Job Submit and List
To prove the utility of the REST API, here are two simple Python programs that imitate the function of the nc run and nc list commands that are familiar CLI tools from the Accelerator product. The source code for these tools, named nc_run.py and nc_list.py, is found on the following pages.
These REST programs only require that the NC_URL environment variable be set to the Accelerator queue URL, as returned by nc cmd vovbrowser. Here is a terminal image that demonstrates the simple REST tools.
% ./nc_run.py sleep 33
Password:
New job is 45080
% ./nc_run.py sleep 66
Password:
New job is 45083
% ./nc_list.py
Password:
ID STATUSNC PRIORITYP HOST COMMAND
000045080 Running normal kfeind1 vw sleep 33 > JOBLOG.1411
000045083 Running normal kfeind1 vw sleep 66 > JOBLOG.1925
nc_run.py
#!/usr/bin/python
# nc_run.py
# Usage
# export NC_URL=<URL FOR NC QUEUE>
# ./nc_run.py <command> [args]
import os, sys, random, string, pwd, json, requests, grp
def runJob(url, jwt, jobCommand ):
resturl = url + "/api/v3/jobs"
VOV_JOB_DESC = {
"command" : jobCommand,
"logfile" : "JOBLOG." + str(random.randint(1000,2000)),
"rundir" : os.getcwd(),
"env" : "BASE",
r = requests.post(resturl, json=VOV_JOB_DESC,
headers={"Authorization": jwt})
if ( r.status_code < 300 ):
print ("New job is %s" % r.json()["jobid"])
return 0
else:
print ("Error code: %d" % r.status_code)
print ("Error message: %s" % r.json()["errormsg"])
return 1
# Main body
nc_url = os.environ["NC_URL"]
scheme = nc_url.split(":")[0]
hostport = nc_url.split("/")[2]
url = "{0}://{1}".format(scheme, hostport)
command = " ".join(sys.argv[1::])
jwt = getJWT( url, os.environ["USER"], getMyPassword())
stat = runJob(url, jwt, command)
exit(stat)
nc_list.py
#!/usr/bin/python
# nc_list.py
# Usage
# ./nc_list.py
import os,sys,random,string
import pwd
import json
import requests
from getToken import getMyPassword
def listJob(url, jwt):
query = ( url + '/api/v3/query'
+ '?select=id,statusnc,PRIORITYPP,host,command'
+ '&from=System:User:' + os.environ['USER'] )
if ( r.status_code >= 300 ):
print ("Error: status %d received" % r.status_code )
exit(1)
return r.text
def prettyPrint( text ):
dd = json.loads(text)
for ii in range(0, len(dd['columns']) ) :
sys.stdout.write("%9.9s " % dd['columns'][ii]['field'])
sys.stdout.write("\n")
if ('rows' not in dd):
return
for rr in range (0, len(dd['rows']) ) :
row = dd['rows'][rr]
if (ii < len(dd['columns'])-1):
sys.stdout.write("%9.9s " % str(row[ii]))
else:
sys.stdout.write("%10.30s" % str(row[ii]))
# Main body
nc_url = os.environ['NC_URL']
json_text = listJob(url, jwt)
prettyPrint(json_text)
