Installation via a Batch Script
On UNIX, you can use a batch install script instead of the GUI version.
Only the New Installation Directory value is a required parameter. The batch install uses a default value for the other fields.
Because this is a new install, the option -local create should be used for specifying the handling of the "local" directory.
% cd /usr/tmp/rtda_download
% ./batch_install.csh /opt/rtda/2020.1 -local create -rlm <port@host> -plat '<platform list>'
% ./batch_install.csh /opt/rtda/2016.09 -local create -rlm 7070@buffalo; -plat 'linux'
batch_install.csh
Run this from the temporary directory where you unpacked the .tar archives to install Altair Accelerator software into the <installationDirectory> target.
Usage
./batch_install.csh <installationDirectory> [OPTIONS]
Options
- -rlm
- port@host or blank
- -local
- L
- -nocommone
- Used when installing additional platforms.
- -confirm
- Prompt for confirmation.
- -noconfirm
- Default. Do not prompt for confirmation. All necessary directories will be created automatically.
- -plat
- 'x y'
- -v
- Increase verbosity of installation process.
Examples
./batch_install.csh /opt/rtda/<version>
./batch_install.csh /opt/rtda/<version> -rlm 7070@croc
./batch_install.csh /opt/rtda/<version> -local create -rlm 7070@croc
./batch_install.csh /opt/rtda/<version> -local link -plat 'linux win64'
Because this is an update install to add a new platform to a
previously installed release, the options -nocommon and
-local copy should be used. The copy
choice
for the local parameter will cause the process to copy the local files onto
themselves, creating a non-destructive no-op operation.
% ./batch_install.csh /opt/rtda/2016.09 -nocommon -local copy -rlm <port@host> -plat '<added-platform>'
% ./batch_install.csh /opt/rtda/2016.09 -nocommon -local copy -rlm 7070@buffalo; -plat 'linux'
Sample Module - Software Environment Management
If your company uses the "Modules" software from http://modules.sourceforge.net/ to manage the environment for the installed tools, the installation script also generates a module file named vov.modulefile to copy into one of the directories of your MODULEPATH where other tool environments are stored.
% mkdir -p /tools/modules/3.2.8a/Modules/modulefiles/vov
% cp /opt/rtda/2020.1/common/etc/vov.modulefile /tools/modules/3.2.8a/Modules/modulefiles/vov/2020.1
% module avail
---------- /tools/modules/3.2.8a/Modules/modulefiles ----------
vov/2020.1 vov/2016.09
