Installation via a Batch Script
On UNIX, you can use a batch install script instead of the GUI version.
Run the command ./batch_install.csh
The values that control the installation are passed into the batch script as command line parameters, except for the Existing Installation Directory. The batch script gets the value for this from the $VOVDIR environment variable as it runs.
Because this is an update install to add a new platform to a previously installed release, the options -nocommon and -local copy should be used. The "copy" choice for the local parameter will cause the process to copy the local files onto themselves, creating a non-destructive no-op operation.
Here is the logical description of calling the batch install for the scenario of adding platform-specific files for a new platform.
% cd /usr/tmp/rtda_download
% ./batch_install.csh /opt/rtda/2020.1 -nocommon -local copy -rlm <port@host> -plat '<added-platform>'
Here is a specific example of doing an update by running the batch install to add the platform Linux64 to the release.
% ./batch_install.csh /opt/rtda/2020.1 -nocommon -local copy -rlm 7070@buffalo; -plat 'linux64'
batch_install.csh
Run this from the temporary directory where you unpacked the .tar archives to install Altair Accelerator software into the <installationDirectory> target.
Usage
./batch_install.csh <installationDirectory> [OPTIONS]
Options
Use the below options for non-interactive installation.
-rlm
port@host or blank
Use port@host as the value of RLM_LICENSE in this installation (ignore this option for license keys).
If option is blank, script will look for key file in local directory.
-local
L
Specific handling of 'local' directory where L=create, copy or link (default).
-nocommone
Used when installing additional platforms.
-confirm
Prompt for confirmation.
-noconfirm
Default. Do not prompt for confirmation. All necessary directories will be created automatically.
-plat
'x y'
Platforms to install. Default is all available. Currently supported: linux, linux64, win64, macosx
-v
Increase verbosity of installation process.
Examples
./batch_install.csh /opt/rtda/<version>
./batch_install.csh /opt/rtda/<version> -rlm 7070@croc
./batch_install.csh /opt/rtda/<version> -local create -rlm 7070@croc
./batch_install.csh /opt/rtda/<version> -local link -plat 'linux win64'
Because this is an update install to add a new platform to a previously installed release, the options -nocommon and -local copy should be used. The copy choice for the local parameter will cause the process to copy the local files onto themselves, creating a non-destructive no-op operation.
% ./batch_install.csh /opt/rtda/2016.09 -nocommon -local copy -rlm <port@host> -plat '<added-platform>'
Here is a specific example of doing an update by running the batch install to add the platform Linux to the release.
% ./batch_install.csh /opt/rtda/2016.09 -nocommon -local copy -rlm 7070@buffalo; -plat 'linux'
