Query the vovserver
The vovselect command provides a way to retrieve specific data from the vovserver, with filtering done on the server side. This method is differs from some of the VTK calls, which get all data and require processing on the client side to get the data of interest.
vovselect fieldname,fieldtype from <object>
to see the list
of fields for that object. Multiple fields may be requested by separating them with
a comma. Some fields represent a data collection that can be broken down using a
format of FIELD.X, such as:
KEY.<KEYNAME> (metric objects)
PARAM.<PARAMNAME> (server object)
PROP.<PROPNAME> (all objects)
RESOURCES.<RESNAME> (slave objects)
vovselect
vovselect: Usage Message
Utility to query vovserver data.
USAGE:
vovselect <FIELDSPEC> from <OBJECT> [OPTIONS]
OPTIONS:
-h -- Show usage syntax.
-v -- Increase verbosity.
-where <FILTER> -- Filter the results.
-order <COLUMN> [ORDER] -- Sort the output by the specified column
and ordering. Ordering is either "asc"
(ascending) or "desc" (descending).
Default ordering is ascending. When
specifying an ordering, place the column
and ordering in quotes, e.g.
-order 'name desc'.
-limit <N> -- Limit the output to N rows.
-distinct -- Return distinct rows.
-header -- Displays column headers in the output.
-cache 0/1 -- Control cacheing of query (default is 1).
Tech Note: use cache 0 for small results
(less than a few thousand rows)
If option values contain shell-sensitive characters, such as ">",
enclose them with single quotes (Linux) or double quotes (Windows).
The from parameter will accept queryable object names (as listed by
"vovselect objectname from objects"), individual object identifiers
(as listed by "vovselect idint from <object>"), or set names
(as listed by "vovselect name from sets"). This parameter can also
accept the following:
SUBSETS.<SETID>
MATCHES.<RESMAPID>
MATCHES.<RESMAPNAME>
SUPPORTED OBJECTS:
Run "vovselect objectname from objects" to see
the list of queryable objects.
SUPPORTED FIELDS:
Run "vovselect fieldname,fieldtype from <object>" to see the list of
fields for that object. To see a list of fields with descriptions run,
"vovselect fieldname,fielddesc from <object>". Multiple fields may be
requested by separating them with a comma. Some fields represent a data
collection that can be broken down using a format of FIELD.X, such as:
SUPPORTED FILTERS:
Use selection rule operators in conjunction with field names to filter
queries. See operator list at URL/doc/html/vov/topics/vov/operators.htm
via web browser. To get the current the URL for current instance, execute
the vovbrowser command.
EXAMPLES:
% vovselect -h
% vovselect objectname from objects
% vovselect fieldname from server
% vovselect id,name from users -order name -limit 10 -header
% vovselect id,name from users -where 'name==joe'
% vovselect id,name from 12345
% vovselect id,name from subsets.23456
% vovselect matchtype,host from matches.License:spice
% vovselect idint,name from users -where 'idint>3600'
-order 'idint desc'
% vovselect id,age from System:running
% vovselect id,age -from System:running -cache 0
Use vovselect for Querying
The nc hosts
command can be used for querying, but it can sometimes
take several minutes to return results, which causes some nodes to show up as "N/A".
nc hosts
will query the server and return significant amounts
of data, but the server loading will directly affect the response time of the
command.
In order to avoid such delay, you can use vovselect
to run the
query, as it prefilters the output server-side before returning it to the
client.
Use the table below to understand the mapping of fields between the nc
hosts
and vovselect
commands.
nc hosts | vovselect from TASKERS | vovselect from HOSTS |
ARCH | ARCH | ARCH |
CAPABILITIES | CAPABILITIES | NA |
CAPACITY | CAPACITY | CPUS |
CLASSRESOURCES | CLASSRESOURCES | NA |
CLOCK | CLOCK | CPUCLOCK |
COEFF | COEFF | NA |
CONSUMABLES | CONSUMABLES | NA |
CORES | CORESAVAIL | NA |
CORESAVAIL | CORESAVAIL | NA |
CORESTOTAL | CORESTOTAL | CPUS |
CORESUSED | CORESUSED | NA |
CPUS | CPUS | CPUS |
CURLOAD | CURLOAD | NA |
DOEXEC | DOEXEC | NA |
DONETINFO | DONETINFO | NA |
DOPROCINFO | DOPROCINFO | NA |
DORTTRACING | DORTTRACING | NA |
EFFLOAD | NA | NA |
EXTRAS | EXTRAS | NA |
FULLINFO | FULLINFO | NA |
GROUP | GROUP | NA |
HB | NA | NA |
HBPP | NA | NA |
HEARTBEAT | HEARTBEAT | NA |
HOST | HOST | NAME |
ID | ID | NA |
IDINT | IDINT | NA |
LASTJOBID | NA | NA |
LASTUPDATE | LASTUPDATE | NA |
LIFETIMEJOBS | LIFETIMEJOBS | NA |
LOAD1 | NA | NA |
LOAD15 | NA | NA |
LOAD5 | NA | NA |
LOADEFF | NA | NA |
MACHINE | MACHINE | MACHINE |
MANUALPOWER | NA | NA |
MAXLOAD | MAXLOAD | NA |
MESSAGE | MESSAGE | NA |
MESSAGESYS | MESSAGESYS | NA |
MESSAGEUSER | MESSAGEUSER | NA |
MODEL | MODEL | NA |
NAME | NAME | NAME |
NUMJOBS | NA | NA |
OSCLASS | OSCLASS | NA |
PERCENT | PERCENT | NA |
PERSISTENT | PERSISTENT | NA |
PID | PID | NA |
POWER | POWER | NA |
RAM | RAM | NA |
RAMFREE | RAMFREE | NA |
RAMTOTAL | RAMTOTAL | RAMTOTAL |
RAWPOWER | NA | NA |
RELEASE | RELEASE | NA |
RESERVEDBY | RESERVEDBY | NA |
RESERVEEND | RESERVEEND | NA |
RESERVEFORBUCKETID | RESERVEFORBUCKETID | NA |
RESERVEFORID | RESERVEFORID | NA |
RESERVEGROUP | RESERVEGROUP | NA |
RESERVEJOBCLASS | RESERVEJOBCLASS | NA |
RESERVEJOBPROJ | RESERVEJOBPROJ | NA |
RESERVEOSGROUP | RESERVEOSGROUP | NA |
RESERVESTART | RESERVESTART | NA |
RESERVEUSER | RESERVEUSER | NA |
RESOURCECMD | RESOURCECMD | NA |
RESOURCES | NA | NA |
RESOURCESEXTRA | NA | NA |
RESOURCESPEC | RESOURCESPEC | NA |
RUNNINGJOBS | RUNNINGJOBS | NA |
SLOTS | NA | NA |
SLOTSTOTAL | SLOTSTOTAL | NA |
STATSREJECTCORES | STATSREJECTCORES | NA |
STATSREJECTOTHER | STATSREJECTOTHER | NA |
STATSREJECTRAM | STATSREJECTRAM | NA |
STATSREJECTRESERVED | STATSREJECTRESERVED | NA |
STATSREJECTSLOTS | STATSREJECTSLOTS | NA |
STATSVISITS | NA | NA |
STATUS | NA | NA |
SWAP | SWAP | NA |
SWAPFREE | SWAPFREE | NA |
SWAPTOTAL | SWAPTOTAL | NA |
TASKERGROUP | TASKER | NA |
TASKERNAME | TASKERNAME | NAME |
TASKERSLOTSSUSPENDABLE | TASKERSLOTSSUSPENDABLE | NA |
TASKERSLOTSSUSPENDED | TASKERSLOTSSUSPENDED | NA |
TASKERSLOTSUSED | TASKERSLOTSUSED | NA |
TASKERTYPE | TASKERTYPE | NA |
TIMELEFT | TIMELEFT | NA |
TMP | TMP | NA |
TYPE | TYPE | NA |
UPTIME | NA | NA |
UPTIMEPP | UPTIMEPP | NA |
USER | USER | NA |
VERSION | VERSION | NA |
VOVVERSION | VOVVERSION | NA |
