Configure the Database from the Command Line
The command line utility vovdb_util can be used to configure most aspects of the Accelerator database. You must have ADMIN privileges on the Accelerator server to configure and control the database.
% vovproject enable vnc
vovdb_util
Utilities for use with the VOV database.
vovdb_util: Usage Message
DESCRIPTION:
USAGE:
% vovdb_util <COMMAND> [COMMON OPTIONS] [OPTIONS]
COMMANDS:
help -- Shows help information.
backup <dest>
-- Backs up the VOV database to the specified destination.
This command must be run on the same machine as the
database. If the destination exists it must be empty.
The database must also be running.
clearcfg [-noconfirm]
-- Resets the VOV database configuration to the initial,
unconfigured state. Pass -noconfirm to skip confirmation.
configure [-v] [-reset] [-noconfirm] <host> <root> [<port>]
-- Sets the host, root data path, and port for the VOV
database. Pass -reset to overwrite existing settings.
showcfg -- Prints out current VOV database configuration.
startdb -- Starts the VOV database. Will restart a running database.
status -- Prints current VOV database status.
stopdb -- Stops the VOV database.
upgrade [-noconfirm] [-noclean]
-- Upgrades the VOV database to use the newest version of the
PostgreSQL engine. There must be enough disk space for a
temporary copy of the database files. The database will be
offline during the upgrade. Pass -noconfirm to skip
confirmation, -noclean to not delete temporary files if the
upgrade fails.
The following commands are only supported for NetworkComputer and
LicenseMonitor.
dump [-pre201509] [-start <YYYYMMDD>] [-end <YYYYMMDD>]
-- Generate data files, optionally limited to the start and
end times specified. Pass -pre201509 to dump the database
that was used prior to upgrade to 2015.09 (or beyond.)
trim <YYYYMMDD>
-- Deletes data prior to the given date.
COMMON OPTIONS:
-v -- Increase verbosity.
Database Configuration Options
Database configuration is handled by the vovdb_util configure command. Pass -reset to overwrite an existing configuration. Pass -noconfirm to skip confirmation.
To show the current configuration, use vovdb_util showcfg. To clear an existing configuration, use vovdb_util clearcfg.
% vovdb_util configure localhost /data/rtda/licmon
vovdb_util 08/17/2016 16:15:03: message: Setting VOV database configuration to:
Host: srv1
Data Path: /data/rtda/licmon
Set configuration (yes/no)? yes
vovdb_util 08/17/2016 16:15:08: message: Configuration saved.
% vovdb_util configure -reset -noconfirm localhost /data/rtda/db/licmon
vovdb_util 08/17/2016 16:15:53: message: Configuration saved.
% vovdb_util showcfg
vovdb_util 08/17/2016 16:16:00: message: The VOV database configuration is:
Host: srv1
Data Path: /data/rtda/db/licmon
Status: stopped
% vovdb_util clearcfg -noconfirm
vovdb_util 08/17/2016 16:15:24: message: Configuration has been cleared.
Database Control Options
Once the database is configured, it can be controlled with the vovdb_util startdb and stopdb commands. There will be additional output the first time the database is started as the on-disk structure is created.
% vovdb_util startdb
vovdb 08/17/2016 16:22:55: message: Creating database
The files belonging to this database system will be owned by user "admin".
This user must also own the server process.
The database cluster will be initialized with locale "en_US.UTF8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
creating directory /data/rtda/db/licmon/dbdata9_4 ... ok
creating subdirectories ... ok
<snip>
vovdb 08/17/2016 16:22:58: message: Starting database
vovdb 08/17/2016 16:22:58: message: LOG: database system was shut down at 2016-08-17 16:22:56 CDT
vovdb 08/17/2016 16:22:58: message: LOG: MultiXact member wraparound protections are now enabled
vovdb 08/17/2016 16:22:58: message: LOG: database system is ready to accept connections
vovdb 08/17/2016 16:22:58: message: Database engine is ready.
vovdb 08/17/2016 16:22:58: message: Configuring database...
vovdb 08/17/2016 16:22:58: message: Creating user 'rtdamgr'
vovdb 08/17/2016 16:22:58: message: Creating user 'rtdausr'
vovdb 08/17/2016 16:22:58: message: Creating database 'rtda'
vovdb 08/17/2016 16:22:58: message: Database configured.
vovdb 08/17/2016 16:22:58: message: Loading schema for LicenseMonitor...
vovdb 08/17/2016 16:22:58: message: Creating table 'metadata'...
vovdb 08/17/2016 16:22:58: message: Granting RO privileges to rtdausr...
vovdb 08/17/2016 16:22:58: message: Creating table 'loadinfo'...
<snip>
vovdb 08/17/2016 16:22:59: message: Schema loaded
vovdb 08/17/2016 16:22:59: message: Database is ready.
vovdb_util 08/17/2016 16:22:59: message: Database started.
% vovdb_util stopdb
vovdb_util 08/17/2016 16:31:22: message: Stopping database...
vovdb_util 08/17/2016 16:31:23: message: Database stopped.
Database Tasks
At present, database tasks such as the automatic loader, daily maintenance, and automatic backups can only be configured through the web interface. Refer to Set Up for more information.
