Access Control List
An Access Control List (ACL) is a list of permissions that are attached to an object. The list defines who can access the object (an agent) and what actions the agent can perform on the object.
An ACL is expressed in terms of operations that are permitted to an agent acting on the object. An agent may be a USER (login account), an OS group (OSGROUP), a FairShare group (FSGROUP), a machine (HOST) or one of the symbolic agents EVERYBODY, OWNER, ADMIN. The most powerful agent is the SERVER. For more information, please refer to the table below.
For the agents that are groups, membership in the group confers the operations
permitted by that ACL. For example, if the login joe
is a member of
the OS group dvregr
, and OSGROUP dvregr
has APPEND
on a fsgroup
, then joe
may add ACLs to that
fsgroup
To bypass the ACL, you must be the logged in on the host running vovserver as the user that is running vovserver, and you must change VOV_HOST_NAME to "localhost".
ACL Management
vovfsgroup <object> <command> <agent> <actionList>
The following utilities are available for ACL management:
Utility | Description |
vovfsgroup | Manage FairShare group ACLs |
ACL Commands
ACL management consists of the following commands:
Command | Description |
GET | Get current ACLs on an object |
RESET | Reset ACLs on an object to defaults (see below) |
APPEND | Add ACLs to an object |
DELETE | Delete an ACL element from an object |
The GET operation shows you the current ACLs that are associated with an object, if the ACL permits you to VIEW it.
ACL 1: OWNER "" ATTACH DETACH EDIT VIEW FORGET DELEGATE EXISTS
ACL 2: EVERYBODY "" ATTACH VIEW
The APPEND operation adds a new ACL to an object.
The DELETE operation removes an ACL element from an object. The element is identified by the agent and name fields.
ACL Agents
Access control is performed each time a client tries to perform a controlled action. The following types of agents that can perform the authorized actions:
Agent | Description |
SERVER | The vovserver binary and the vovserver owner connected to the server on the loopback port (localhost = 127.0.0.1). This is the most powerful agent and has the ability to change owner of some objects |
ADMIN | All users that have been assigned as project administrators |
EVERYBODY | All users in the system |
OWNER | The project owner |
HOST name | All users coming from a specific host |
USER name | A specific user |
OSGROUP name | All users in a specific OSgroup |
FSGROUP name | All users in a specific FairShare group |
ACL Actions
Following are the actions that can be controlled via ACLs:
Action | Description |
EXIST | The agent is aware of the existence of the object |
VIEW | View properties of an object |
ATTACH | Create a relationship between objects |
DETACH | Destroy a relationship between objects |
EDIT | Modify properties of an object |
RETRACE | Retrace an object |
STOP | Stop an object |
SUSPEND | Suspend an object |
FORGET | Forget an object |
DELEGATE | Assign ACLs on an object |
Obtain SERVER Credentials
- Login on the vovserver host as the user that is running vovserver
- Enable the project with
vovproject enable PROJECTNAME
- Change the VOV_HOST_NAME to
localhost
% setenv VOV_HOST_NAME localhost
- Now your clients act as the SERVER agent with respect to the ACL
