Tuning vovfilerd
You may need to refine the tuning of the L1,L2,L3 limits that define the behavior of vovfilerd for each specific filer. We suggest a simple experiment that will help you see the effect of storage-aware-scheduling and also may help you decide on the tuning.
The experiment consists of running two I/O intensive workload (using dd) first with Storage Aware Scheduling and then without. The difference in behavior can be monitored in the browser interface. The suggested workload consists of only "write-to-disk" operations, so it is by definition an extreme workload. Real workload will behave better that this experiment.
% vovfilerdgui -show
% vovfilerdgui -f FS1 &
% cd some/directory/on/filer/FS1
% mkdir OUT
% setenv VOV_JOBPROJ SASyes
% time nc run -w -r Filer:FS1 -array 5000 dd of=OUT/dd_@INDEX@.out
if=/dev/zero count=1024 bs=102400
% mkdir OUT
% setenv VOV_JOBPROJ SASno
% nc run -array 5000 dd of=OUT/dd_@INDEX@.out if=/dev/zero
If you have a big enough farm, say close to 1000 cores, you will see that this second workload uses all machines you have and creates even larger level of latency on the filer. The jobs, which should take about 1s each, may end up taking minutes to run because of such congestion. If the jobs also required a license, that license would be used by the job for way longer than it was earlier with storage aware scheduling.
In this report you see the two workloads. (In this plot the SASno experiment comes before the SASyes experiment). Look at the average run time of the jobs. In SASyes experiment, the average duration is 5 seconds, while in the SASno experiment the average duration is 2m47s, i.e. 33 times longer!
