Preemption Rules
- The resources that can be preempted
- Conditions under which preemption should be triggered
- Methods used to revoke those resources
- Create and edit the rules with Accelerator's web interface. The rules are stored within the vovserver and saved to disk from time to time. The rules are automatically loaded when Accelerator is restarted.
- Define the rules in the Tcl syntax configuration file at vnc.swd/vovpreemptd/config.tcl. When the vovpreemptd daemon starts, it reads the config.tcl file containing the preemption rule information. The daemon monitors this file and reads it again upon changes. The daemon also creates the info.tcl file which contains information about the daemon and serves as a lock file to prevent two instances of the daemon from running. The daemon tracks the modification time of the info.tcl file, and will exit if the time is changed, for example by another instance of vovpreemptd.
Preemption rules define the conditions under which preemption is to be performed. These rules are either defined using the VovPreemptRule command (defined below) and/or via Accelerator's web page interface.
- Only one rule in a pool fires for a given iteration; rules are considered in order (as defined with the -order <N> option). This order of executing rules can use used to set up escalation. For example, if the current rule has not fired, then consider the next rule. The first rule could be for a small set of preemptable jobs, the second rule could be for a much larger set of preemptable jobs.
- Multiple pools allow different preemption strategies to be considered in parallel; one pool could be for Design Verification jobs, while another pool could be for spice simulation jobs.
By default, all rules are added to the pool called mainpool. For multiple rules to fire during each preemption cycle, the rules must be organized into different pools.
Preemption Conditions
- There is a bucket of jobs that matches a given selection rule (use the
-preempting
and-bucketage
options) - There is a bucket of jobs that is waiting for at least one of a list of resources (use the -waitingfor and -bucketage options)
- There is a resource map that is controlled by MultiQueue and MultiQueue is
currently requesting a drastic reduction (at least 10% of the current
"in-use" S count) in the amount allocated to this queue (see option
-multiqueueres
). The 10% threshold can be controlled by means of the option-mqthresh
The weakest types of preemption are the RESERVE_RESOURCES
and
RESERVE_TASKERS
methods.
RESERVE_RESOURCES
simply reserves some resources for the job at
the top of the bucket and
simply reserves a tasker for the
job at the top of the bucket. It is the intended behaviour that while the resources
or RESERVE_TASKERS
taskers
are reserved, some other jobs will
terminate and enable the job at the top of the bucket to be dispatched. The
reservation is controlled by the options -reservetime
-reservefor
, and -reservenum
If the preemption type is not RESERVE_RESOURCES
or RESERVE_TASKERS
, then the system looks for jobs that can
be preempted, i.e., that can be either killed or suspended.
The strongest type of preemption is FREE_TASKERS
which looks at ways to preempt all jobs currently running on a
tasker.
Search for Preemptable Jobs
- Exclude jobs that have the
preemptable
flag set to zero; - Exclude jobs that are "system" jobs (like job resumers, zip jobs, ... )
- Exclude jobs that are labeled as top job, which are jobs that have
caused a preemption in the past, because they were at the top job in a
preempting bucket. The jobs are left alone for at least 10 minutes, a time
interval that can be controlled with the option
-donotdisturb
<timeSpec>.
- Look for jobs that can be killed, or more precisely withdrawn, and
resubmitted, which are the jobs that satisfy the
-preemptable
selection rule and that are younger than-killage
. These jobs also must be useful in the sense that they hold some resources requested by the preempting job. Preemption will not kill jobs that are not considered useful for the preempting job. - If no job can be killed, then look for jobs that satisfy the
-preemptable
selection rule and are also useful. If any such job is found, preemption is attempted using the method specified by the-method
option. Some jobs are resilient to some preemption methods, so care is applied to validate that the method has been effective. - If the preempted job is successfully suspended, then a resumer job
associated with the suspended job is created. The resumer job is an
invocation of the script
vovjobresumer
. The resumer job inherits the grabbed resources from the suspended job, meaning that it will be executed only when all resources grabbed from the suspended job become available. The resource list of the resumer job can also be augmented with the option-resumeres
Preemption Rule Types
Preemption was previously defined as the process of revoking resources from a running job or reserving resources in order to start a 'more urgent' queued job that needs specific resources that are not currently available. Consequently, rules are divided into specific types based on how the resources are to be made available to such 'more urgent' job.
The rule type is specified via the -ruletype option in VovPreemptRule, and the default rule type is "GENERIC".
-pool
-rulename
-ruletype
-order
-debug
-enabled
-fireonce
-preempting
-bucketage
-waitingfor
RESERVE_TASKERS
The rules with type RESERVE_TASKERS
are the
simplest and least intrusive. Such rules when fired add a reservation of some
specified tasker(s) for some specified period of time. When jobs
terminate on a reserved tasker, those open slots are reserved to
the jobs in the preempting bucket.
- -reservenum
- -reservetasker
- -reservefor
- -reservetime
- -preempttaskerspec
Since no jobs are preempted, options such as -method and -preemptable are not needed and will be ignored.
For example, the following rule reserves a number of taskers for
one minute for any job in the hsim_critical
jobclass:
# # Reserve some machines for one minute if there is a critical hsim job. # VovPreemptRule -rulename "ReserveOnlyHsimHw" \ -preempting "jobclass==hsim_critical" \ -ruletype RESERVE_TASKERS \ -reservetasker "taskerlist:dram4" \ -reservefor "JOBCLASS hsim_critical" \ -reservenum 1 \ -reservetime "1m"
RESERVE_RESOURCES
RESERVE_RESOURCES
are similar to the
RESERVE_TASKERS
type; however, instead
of reserving taskers, these rules reserve resources for some
specific reservation period. The resources reserved are the resources that the
preempting job is waiting for and will be reserved for the preempting job for the
time specified via the -reservetime option. Since no jobs are
preempted, the options -method and -preemptable
are ignored. The following is meaningful options for RESERVE_RESOURCES ruletype. - -reservetime
VovPreemptRule \
-pool "mainpool" \
-rulename "ReserveLicenseLargeJobHighPriority" \
-ruletype "RESERVE_RESOURCES" \
-preempting "Priority>8 JOBCLASS=LargeJob" \
-bucketage "5m" \
-waitingfor "License:*" \
-reservetime 2m
MULTIQUEUE
- -multiqueueres
- -mqthresh 0.25
- -donotdisturb
- -preemptable
- -killage
- -method
- -skipresumedjob
- -resumeres
- -numjobs
- -maxattempts
- -sortjobsby
VovPreemptRule -rulename "mqPreemptHsim" \
-ruletype MULTIQUEUE \
-multiqueueres License:hsim \
-mqthresh 0.25 \
-pool multiqueue \
-method AUTOMATIC
GENERIC
The preemption type GENERIC
is the most common. It is designed to
find running jobs that can be preempted to provide for resources in order to
dispatch the preempting job.
- -donotdisturb
- -preemptable
- -killage
- -method
- -skipresumedjob
- -resumeres
- -numjobs
- -maxattempts
- -sortjobsby
For reference, it may be best to review the options for the vovpreemptrule command for more detailed explanation of the options available for the command.
# Preempting rule is activiated when any job with priority greater than
# or equal to 8 AND is waiting for License:hsmi AND has been waiting
# more than 2 minutes. It will preempt any job with priority less
# than the preempting job AND is using resource License:hsmi.
# The preemptable job will be killed and resubmitted if it has been
# running less than 1 minute. Otherwise, it will be preempted via the
# AUTOMATIC method.
VovPreemptRule -rulename "priority" \
-ruletype GENERIC \
-preempting "PRIORITY>=8" \
-waitingfor "License:hsim" \
-bucketage 2m \
-preemptable "PRIORITY<@PRIORITY@" \
-killage 1m \
-method SIGTSTP
FAST_FAIRSHARE
FAST_FAIRSHARE
preemption is intended to help speed up FairShare. The rule type is mainly used by the
NC
web page preemption rule entry page to pre-enter the
interesting FairShare related fields for the preempting and
preemptable condidtions in the selection rules. Internally, it is processed exactly
the same as the GENERIC
rule type.
FREE_TASKERS
This is one of the strongest preemption types, because it can preempt all jobs on a
tasker at the same time to make space for the preempting job.
This type preempts necessary number of taskers and jobs on those
taskers enough to run jobs in the preempting bucket. Also the
number of taskers to get preempted does not exceed
-preempttaskernum
- -donotdisturb
- -preemptable
- -preempttaskernum
- -method
- -skipresumedjob
- -resumeres
VovPreemptRule \
-pool "mainpool" \
-rulename "taskerFree" \
-ruletype "FREE_TASKERS" \
-preempttaskerspec "TASKERLIST:default" \
-waitingfor HW \
-bucketage 10 \
-preempting "JOBCLASS==design PRIORITY>=8 REQCORES>=4" \
-preemptable "JOBCLASS==regression" \
Command Line Interface for Preemption Rules
Here are some useful commands to manage preemption rules.
% vovshow -preemptrules
002772887 test testFreeTaskerRule KILL+RESUBMIT 101
002774006 Micron mic_pri KILL+RESUBMIT 102
002774004 Micron mic_mq KILL+RESUBMIT 101
002775275 mainpool FormalRegressions SUSPEND 101
002774085 mainpool testStealResource AUTOMATIC 102
002775412 mainpool PreemptAth AUTOMATIC 103
002774511 mainpool byPriority SUSPEND 101
002777727 RegrTestPool RegrTestPriority1523033980 KILL+RESUBMIT 50
002778828 RegrTestPool RegrTestThomas 0:*:EXT,KILL 10:WITHDRAWN:RESUBMIT 50
002777743 RegrTestPool ReserveTaskersForTest AUTOMATIC 101
002774829 mainpool HelpStiffJobs AUTOMATIC 101
002778200 mainpool pRule4613 SUSPEND 101
002778064 mainpool rr41523034013 AUTOMATIC 50
002775429 HERO Test_Priority_Same_User SUSPEND 101
002777656 TESTPOOL TestMethodnormal AUTOMATIC 103
002778839 RegrTestPoolMQ RegrTestMQ1523034523 SUSPEND 55
% vovforget -preemptrules
% vovshow ID_OF_PREEMPT_RULE
% vovforget ID_OF_PREEMPT_RULE
% vovshow -preemptmethods
1 JOBHANDLER_VOVSH 0:*:EXT,SIGTSTP,vovsh 5:SUSPENDED:NOLMREMOVE
2 SIGTSTP+LMREMOVE *:RETRACING:SIGTSTP 5:WAIT:SUSPEND 10:SUSPENDED:LMREMOVE 20:LMREMOVED:DONE
3 SUSPEND *:*:SUSPEND
4 SIGTSTP+SUSPEND *:RETRACING:SIGTSTP 5:WAIT:SUSPEND
5 SIGTSTP *:*:TSTP
6 KILL+RESUBMIT 0:*:KILL 3:WAIT:NOP 30:WITHDRAWN:RESUBMIT
7 LMREMOVE *:*:SUSPEND 10:SUSPENDED:LMREMOVE 20:LMREMOVED:DONE
8 AUTOMATIC *:*:*
9 JOBHANDLER 0:*:EXT,SIGTSTP,tclsh* 5:SUSPENDED:NOLMREMOVE
Tcl Interface to Preemption Rules
# This is Tcl.
VovDumpPreemptionRules NameOfFile.tcl
% vovshow -api preempt
vtk_preemptrule_create DESCRIPTION_ARRAY
vtk_preemptrule_modify DESCRIPTION_ARRAY
vtk_preemptrule_forget ID
vtk_preemptrule_delete ID
vtk_preemptrule_find POOL RULENAME
vtk_preemptrule_get ID RESULT_ARRAY
vtk_preemptrule_delete_all
vtk_preemptrule_forget_all
# This is Tcl.
vtk_transition_preempt jobId [-noop] [-manualresume] [-method METHOD] [-resumeres RESLIST]
vovpreemptrule
Usage: VovPreemptRule -rulename NAME [OPTIONS]
Options:
-pool POOLNAME -- The rule belongs to a pool of rules.
At most one preemption can occur for each pool
in each preemption cycle (default: mainpool)
-rulename NAME -- Required.
-ruletype TYPE -- The type of preemption rule. Allowed values are
GENERIC, FAST_FAIRSHARE, MULTIQUEUE, RESERVE_RESOURCES,
RESERVE_SLAVES, and FREE_SLAVES (default: GENERIC)
-order INTEGER -- Specify the order of evaluation of rules within the same pool.
Rules are evaluated from low to high order. If not specified
the order is assigned automatically based on order of declaration.
Typical range is small positives from 0 to 1000, but the order
can be any integer.
-enabled BOOL -- To enable and disable the rule.
-enable BOOL -- Same as -enabled (obsolete).
-debug BOOL -- To control debugging flag for this rule.
-fireonce BOOL -- To control the fire-once flag.
-preempting SELRULE -- A selection rule for the top job in a bucket.
-waitingfor RESLIST -- If set, the top job in the bucket must be waiting
for at least one of the
given resources in order to trigger a preemption.
If the RESLIST contains the string 'HW', then
preemption is triggered if a job waits for a slot.
-bucketage TIMESPEC -- Only apply the preemption if the bucket age
is greater than the specified value.
-multiqueueres RESLIST -- Trigger preemption if a multiqueue resource (rank>20)
is imbalanced.
-mqthresh THRESHOLD -- Percent reduction in MQ allocation that triggers
preemption. Default 0.1=10%
-donotdisturb TIMESPEC -- Do not preempt a job that was a top-job (i.e. a job
that triggered some preemption) for at least the specified
time (default 10m)
-preemptable SELRULE -- A selection rule for the running jobs
that should be preempted. Any field of the
form @FIELD@ is replaced by the corresponding
value for the top job in the bucket.
-preemptslavespec SPEC -- If preempting job is waiting for hardware,
preempt slaves that match the given SPEC.
The SPEC may include "SlaveList:NAMEOFSLAVELIST"
and selection rules for slaves, like "HOSTNAME=lnx01,lnx02 RANDOM>5000"
Used for FREE_SLAVES rules.
-preemptslavenum N -- For FREE_SLAVES rules, how many slaves to preempt for each bucket
that matches the preempting rule. In any case, we never preempt more
slaves than there are jobs in the bucket. Default is 1.
Use a higher number if you are preempting many jobs for better performance.
-killage TIMESPEC -- Jobs younger than this age are simply killed
and resubmitted. Limited to 7 days max and default
is 0 which implies that killage is not used.
-method METHOD -- The method to be used to recover license
resources from the job. Allowed values are
SUSPEND, LMREMOVE, RESERVE, AUTOMATIC.
If AUTOMATIC, then each license is removed using
the specific method defined with VovPreemptMethod.
Default: AUTOMATIC
-skipresumedjob TIMESPEC -- Do not preempt jobs that have been resumed
no more than TIMESPEC ago.
Default: 2m
-reservetime TIMESPEC -- How long resources should be reserved for the
top job when attempting preemption (default 20)
-reservetype RESTYPE -- Deprecated. Use reservefor.
-reservenum N -- How many slaves are to be reserved for RESERVE_SLAVES rule type.
Default: 1
-reserveslave SLAVENAMES -- If a job is waiting for hardware, this is a space-separated list
of slaves to reserve for the job. It is also possible to include
a slave list by using the keyword 'SlaveList:NAME_OF_SLAVE_LIST'.
-preemptslavespec is used if the field is empty.
-reservefor RESSPEC -- Specify how to reserve a slave. The RESSPEC is
a space-separated list of KEY VALUE, where KEY is
one of BUCKET USER GROUP JOBCLASS JOBPROJ OSGROUP JOBID and VALUE
is a comma-separated list of values (also symbolic like @USER@).
VALUE of BUCKET and JOBID entered here is ignored and
preempting job ID and bucket ID are used.
Default is BUCKET.
-resumeres RESLIST -- List of resources to append to the resumer job.
RESLIST can contain field references (e.g. @HOST@)
which are taken from the preempted job.
-resumedelay TIMESPEC -- Set the minimum delay before executing the resumer job,
where TIMESPEC is the span of time between job
suspension and future time when the resumer job
will be considered for scheduling again.
Default: 5s
-numjobs N -- The maximum number of jobs preempted per bucket per
preemption cycle.
-maxattempts N -- The maximum number of attempts to match the rule for a
preempting job. Setting this to zero (0) disables the check
meaning that the rule can be matched an unlimited number of times
which is useful for example for RESERVE_* type rules.
-sortjobsby N -- Criteria to sort/order potential preemptable jobs.
Format is:
<fieldname> [ASC|DESC] [, <fieldname> [ASC|DESC]]*.
Default is 'PRIORITY ASC, AGE ASC'.
Debug VovPreemptRule
To make sure the rules works as intended, it is useful to look at how the preemption algorithms work in detail. Detailed logs will be written into a log file separate from server log as named server_preemption_DATE.log.
Set the server parameter preemption.log.verbosity
to a number
between 0 and 10. For preempt rules of interest, turn on the debug flag through Web
UI. To log all preempt rules, set the server parameter
preemption.log.allrules
to 1.
- Taskers preempted, jobs preempted, reservations made on taskers and resources, and durations of preempted jobs.
- Preempt rules that trigger for jobs in each bucket. Reasons why rules get disabled. Time taken to process rules if it is significant.
- Which taskerlist is used. Which tasker is missing.
- Why each tasker is not selected. Reasons may be bad tasker status, HW not compabible, already reserved, or select rule not applicable.
- Report all job status being preempted. Each job preempted with which plan. Reserving critical resource. Skip job after max attempt.
- Report how all preempted jobs are handled. Which jobcontrol method is applied.
- Why preempt rule is not triggered. Why taskers are not chosen (already reserved, invalid reserve spec.).
- Details about choosing preemptable target such as waiting for HW and SW, running jobs that have resources managed by Allocator, jobs that have useful resources, wait reasons, preemptable analysis, missing resources.
- Time taken to process preempt rules.
- Which rule is disabled. Miscellaneous messages.
