Jobname Attribute
The jobname is an attribute of a job.
- The jobname does not need to be unique for each job.
- The jobname, if defined, is used in the GUI as the primary label for the jobs; otherwise, the tool name is used.
- The field associated with the jobname is @JOBNAME@.
N "Clock Routing"; # A short name for the job.
J vw /some/long/path/to/an/executable/script/script.pl arg1 arg2
Jobname in Accelerator
% nc run -N this_is_my_job sleep 100
For all products, strict job name checking has been enabled and invalid job name characters will cause an error. For Accelerator and Accelerator Plus, this can be overridden by putting the following in $VOVDIR/local/vncrun.config.tcl:
set ::jobname_lexicon legacy
or set ::jobname_lexicon
replace
Legacy
will use the more lax job naming rules from earlier releases.
Replace
will identify invalid characters in the job name, replace
them with "_", and issue a warning to the console.
