Set Feature Capacity
Monitor tracks the capacity of licenses in addition to utilization data. This is done so automatically with a periodic job, via the SNAPSHOT_CAPACITY task by loading a snapshot of the capacity of all features every hour by default, comparing the values against what is in the database and if they differ, inserting a new capacity value for each feature. In parallel, a data file also maintains a history of the capacity changes. This data file is useful for multi-site situations to aggregate capacity data to a parent site.
The ftlm_capacity utility is used to show and manage the capacity values in the Monitor database. The utility provides the following functions:
  • Show existing capacity values
  • Reload capacity values
  • Set capacity value for a specific feature for a specific time
Operation
To execute ftlm_capacity, first setup the CLI:
% vovproject enable licmon
After setting up the CLI, the command can be executed:
ftlm_capacity: Usage Message
      Manages feature capacity information in the LicenseMonitor database.
      SYNOPSIS:
      % ftlm_capacity <ACTION> [OPTIONS]
      ACTIONS:
      show                -- Show latest capacity information.
      dump                -- Same as show, only with Unix timestamps.
      clear               -- Clear capacity data from database.
      checkmismatch       -- Check mismatch between latest DB capacity and live
                             data. Requires a tag to be specified with -tag.
      fixmismatch         -- Fix mismatches that are found with checkmismatch.
      load                -- Load information about capacity by parsing the
                             resources logs (in licmon.swd/logs/resources*)
      snapshot            -- Snapshot capacity info using current information.
      snapfromfile <FILE> -- Load snapshot capacity info from file. This action
                             does not work with the tag/feature/start/finish
                             options below.
                             Format of the file: setCapacity TAG FEATURE
                             TOKENS TIMESTAMP
      set <TAG> <FEATURE> <TOKENS> <DATE_SPEC>
                          -- Set a new data point in the capacity table.
      setforward <TAG> <FEATURE> <TOKENS> <DATE_SPEC>
                          -- Same as 'set' but delete all points where the
                             timestamp is greater than the specified timestamp.
      OPTIONS:
      -v                     -- Increase verbosity.
      -all                   -- For show and dump, display all capacities as
                                opposed to the latest only.
      -n                     -- Dry-run mode for write operations.
      -tag     <TAG>         -- Constrain to a specific tag.
      -feature <FEATURE>     -- Constrain to a specific feature.
      -start   <DATESPEC>    -- Specify start for load, show, and dump actions.
      -finish  <DATESPEC>    -- Specify finish for load, show, and dump actions.
      -srcdir  <DIR>         -- Directory with the resources*log files.
                                Default: *.swd/logs
      -wavedir <DIR>         -- Directory where waves should be stored.
                                Default: *.swd/logs/waves
      -force                 -- Prevent redundant point detection for
                                snapfromfile action.
      EXAMPLES:
      % ftlm_capacity show
      % ftlm_capacity dump
      % ftlm_capacity show -feature hspice
      % ftlm_capacity dump -tag EDA -feature hspice -start 20090215
      % ftlm_capacity load
      % ftlm_capacity load -tag EDA
      % ftlm_capacity set EDA hspice 12 "1 year ago"
      % ftlm_capacity setforward EDA hspice 12 "1 year ago"
      % ftlm_capacity clear -tag EDA
      % ftlm_capacity snapshot
      % ftlm_capacity snapfromfile licmon.swd/data/capacity/2011.01.01.cap
