Joint Configuration for Parsing Debug Logs (Web Based)
To set up Monitor for joint configurations, perform the following steps:
  1. Go to the Admin tab and select Monitors.
  2. Scroll down to the Edit Monitors section, select a monitor and click Edit. If you don’t see the Edit option, go to the File Configuration section.
    Figure 1. Monitor Administration – Parse a Debug Log
    Click the Update <Tag Name> button.
  3. Enter the path to the debug log (use the @DATE@.nameoflog)
    Note: For either key word to work, the date must be in the format yyyyMMDD.
  4. Enter the Time zone, if different from that of Monitor.
  5. Click Update <Tag Name>.
