X-Formation LM-X
Usage
add_LMX <HOST|PORT@HOST> [OPTIONS]
Options
HOST|PORT@HOST The first argument MUST be the LM-X license server host name or a combination of the port and host name, in PORT@HOST format.
cmd <PATH> Choose a specific sampling command. The default is lmxendutil.
-tag <TAG> Specify the TAG to identify the license server. The TAG may contain only alphanumeric characters and underscores (_). The use of upper case characters is recommended for style purposes.
-minPeriod <TIMESPEC> Minimum sampling period.
-maxPeriod <TIMESPEC> Maximum sampling period.
-autokill <TIMESPEC> Kill parsing job after specified time.
