Examples: Job Submit and Job Info
The following are two simple Python programs that imitate the function of the nc run and nc info commands, only this time these programs are implemented by calling the vov_rest_v3.py package member functions. See the following pages for the source code for these tools, named nc_run2.py and nc_info.py.
These REST programs require that the NC_URL environment variable be set to the Accelerator queue URL, as returned by nc cmd vovbrowser. Here is a an example that demonstrates them.
% export NC_URL="`nc cmd vovbrowser`"
% ./nc_run2.py sleep 33
Password:
New job is 45080
% ./nc_run2.py sleep 66
Password:
New job is 45083
% ./nc_info.py 45083
Password:
Id,User,Group     000045083,kfeind,/time/users
Command           vw sleep 33 > JOBLOG.1293
Status            Running
    Grabbed       Priority:normal#1 User:kfeind#1 Group:time_users#1
    Host          sdc-s15s-2
    Slave         localhost
    Duration      20s
Job 000045083 is Running
nc_run2.py
#!/usr/bin/python3
# nc_run2.py
# Usage
#               export NC_URL=<URL FOR NC QUEUE>
#               ./nc_run2.py <command> [args]
import os, sys, random, pwd, json, grp, getpass
IPATH = os.path.join(os.environ["VOVDIR"], "../common/scripts/python")
sys.path.append(IPATH)
import vov_rest_v3
def getMyPassword():
    return getpass.getpass('Password:')
# Main body
nc_url = os.environ["NC_URL"]
scheme = nc_url.split(":")[0]
hostport = nc_url.split("/")[2]
url = "{0}://{1}".format(scheme, hostport)
command = " ".join(sys.argv[1::])
vrest = vov_rest_v3.VOVRestV3()
vrest.authorize(url, getMyPassword())
# Job attributes - required
VOV_JOB_DESC = {
    "command" : command,
    "logfile" : "JOBLOG." + str(random.randint(1000,2000)),
    "rundir" : os.getcwd(),
    "env" : "BASE",
# Job attributes - optional / User specified
VOV_JOB_DESC.update( {
    "priority,sched" : 4,
r = vrest.submitRequest("POST", url + "/api/v3/jobs", jsonData=VOV_JOB_DESC)
print ("New job is %s" % json.loads(r)["jobid"])
nc_info.py
#!/usr/bin/python3
# nc_info.py
# Usage
#      ./nc_info.py JOB_ID
import os, sys, json
import vov_rest_v3
    import getpass
def infoPrint( text ):
    dd =  json.loads(text)
    id    = find(dd, 'ID')
    user  = find(dd, 'USER')
    group = find(dd, 'GROUP')
    print ("%-16s%s,%s,%s" % ("Id,User,Group", id, user, group))
    print ("%-16s%s" % ("Command", find(dd, 'COMMAND')))
    print ("%-16s%s" % ("Status", find(dd, 'STATUSNC')))
    print ("%-16s%s" % ("   Grabbed", find(dd, 'GRABBEDRESOURCES')))
    print ("%-16s%s" % ("   Host", find(dd, 'HOST')))
    print ("%-16s%s" % ("   Slave", find(dd, 'SLAVENAME')))
    print ("%-16s%s" % ("   Duration", find(dd, 'DURATIONPP')))
    print ("Job %s is %s" % (id, find(dd, 'STATUSNC')))
def find(jobdump, key):
    for c in range (0, len(jobdump['columns'])):
        if (jobdump['columns'][c]['field'] == key):
            break
    return jobdump['rows'][0][c]
# Main body
nc_url = os.environ['NC_URL']
jobid = sys.argv[1]
query = url + '/api/v3/jobs/' + jobid
json_text = vrest.submitRequest("GET", query)
infoPrint(json_text)
