vtk_flexlm_monitor Procedures
Your Accelerator setup will get license in-use info from your Monitor or Monitor-basic setup via HTTP on Monitor's /raw interface. The default resources.tcl file for Accelerator includes the vtk_flexlm_monitor_all procedure. This converts every feature monitored by Monitor into an Accelerator resource, the name of which is the feature name prefixed by 'License:'.
If you do not wish to have a large number of resources, you can comment out the above and put calls to the vtk_flexlm_monitor procedure in your resources.tcl file to specify which FlexNet Publisher features Accelerator should monitor.
