Manage Tasker Lists
A tasker list is a named, ordered list of taskers. Tasker lists can be used to enhance performance or restrict usage.
Examples include:
  • Make the scheduler more efficient on large farms.
  • Pack jobs more tightly on the farm machines.
  • Restrict jobs to selected taskers.
Every vovserver has at least one tasker list named default, which includes all the taskers in the system. The order of the taskers is determined by the connection order unless modified by the commands shown below. The default list cannot be deleted or recreated; taskers can be reordered in the default list.
A tasker list can contain all taskers or a subset of taskers. A tasker list can also be empty.
Note: Typically, a small number of tasker lists are setup for a system, approximately 20. A large number of tasker lists may result in inefficient searches for available resources.
An administrator can create, modify and delete tasker lists with the utility vovtaskerlist.
vovtaskerlist
Manipulate tasker lists.
vovtaskerlist: Usage Message
  DESCRIPTION:
  USAGE:
      % vovtaskerlist ACTION [OPTIONS]
  OPTIONS:
      -h                  -- This help
      -v                  -- Increase verbosity
     Actions:
      create               -- Create a new list
      append
      first
      last
      get                 -- Get taskers in a list
      list                -- List all tasker lists
      delete              -- Delete specified tasker list
      bigram              -- Create list of taskers with a lot of ram
      smallram            -- Create list of taskers with little ram
     Note: actions can also have a dash (list and -list)
  EXAMPLES:
      % vovtaskerlist create planets "pluto jupiter uranus"
      % vovtaskerlist get  planets
      % vovtaskerlist list
      % vovtaskerlist first planets jupiter
      % vovtaskerlist last planets jupiter
      % vovtaskerlist delete  planets
      % vovtaskerlist -bigram 10000      ;; Make a list of taskers with more
                                           than 10GB of RAM
      % vovtaskerlist -smallram 2000     ;; Make list of all taskers with less
                                           than 2GB of RAM
nc taskerlist
Any user can view the tasker lists with the nc taskerlist command.
vnc: Usage Message
      NC SLAVELIST
          Support slave lists.
          SlaveLists are named, ordered lists of slaves.
      USAGE:
          % nc slavelist [OPTIONS]
      OPTIONS:
          -h        -- This help
          -v        -- Increase verbosity,
          -list     -- List all available slavelists
          -get LIST -- Get the ordered slaves in the
                       specified LIST
      ADDITIONAL INFO:
        To manage the slave lists, you have to be ADMIN
        and you can use the vovslavelist utility.
      EXAMPLES:
          % nc slavelist -list
          % nc slavelist -get NAMEOFLIST
          % nc run -r SlaveList:NAMEOFLIST ...  -- myjob
Create and Delete Taskerlists
The following example creates a taskerlist named big that contains five machines:
% vovproject enable vnc
% vovtaskerlist create big "lnxbig01 lnxbig02 lnxbig03"
% vovtaskerlist append big "lnxbig04 lnxbig05"
To delete the list, use the following command:
% vovtaskerlist delete big
A list can be reordered by moving selecting taskers first or last: to the beginning or to the end of the list, respectively. These commands can also be used on the default list.
% vovtaskerlist first big lnxbig05
% $VOVDIR last  big lnxbig01
The vtk API for Tasker Lists
vovtaskerlist_create LISTNAME "list of tasker"
vovtaskerlist_append LISTNAME "list of tasker"
vovtaskerlist_first  LISTNAME "list of tasker"
vovtaskerlist_last   LISTNAME "list of tasker"
vovtaskerlist_get    LISTNAME
vovtaskerlist_delete LISTNAME
vovtaskerlist_list
The following example uses the vtk AP to create a vovtaskerlist that is in the reverse order of the default list.
% vovsh -x 'vovtaskerlist_create reverse [lreverse [vovtaskerlist_get default]]'
Choose a Tasker List for a Job
To choose a tasker list, use the resource "TaskerList:LISTNAME" when submitting the job.
% nc run -r TaskerList:big -- sleep 100
If the specified list does not exist, the job will not run.
