Start and Stop Accelerator
rtdamgr
(or the user chosen as Accelerator
administrator) on the machine that is designated as the vovserver, and the use the following
command:% ncmgr start
% ncmgr stop
% ncmgr stop -freeze
% ncmgr start -force
Reset Accelerator and Restart Taskers
Changes made to Accelerator's configuration files can be read in by performing a reset of the queue. The default behavior is to re-read all configuration files. There are also two optional reset types: soft and hard.
- Soft Reset (-soft)
- A soft reset instructs all running taskers to re-read minor configuration changes and starts configured taskers that are not running at the time. Running jobs are not disturbed.
- Hard Reset (-hard)
- A full reset stops and restarts all taskers. This is a forceful command and will kill all running jobs.
vncmgr: Usage Message
Utility to reread configuration files and start/restart slaves.
USAGE:
% ncmgr reset [OPTIONS]
OPTIONS:
-help -- Print this message
-queue <name> -- Specify the queue name
-soft -- Starts any stopped, but configured slaves
-slaves -- Same as -soft
-hard * -- Stops and starts all slaves (jobs are lost)
-full * -- Same as -hard
* Warning: These options will forcefully stop all running jobs
EXAMPLES:
% ncmgr reset
% ncmgr reset -slaves
% ncmgr reset -full
% ncmgr reset -soft
% ncmgr reset -hard
% ncmgr reset - Reread configuration files
% ncmgr reset -queue vnc2 - Reread configuration files for vnc2 queue
% ncmgr reset -soft - Reread configuration files and start taskers that are not running
% ncmgr reset -hard - Reread configuration files and restart all taskers
For an example of using the full reset option, refer to Directories and Files.
Start Accelerator at System Boot Time
The instructions in this section are valid for Linux only. This part of the installation requires root permission.
The Accelerator vovserver can be restarted at reboot by installing the proper script in both the /etc/rc3.d and /etc/rc5.d directories.
% /bin/su
% cp $VOVDIR/etc/boot/S99nc /etc/rc2.d/S99nc
% chmod 755 /etc/rc2.d/S99nc
% vi /etc/rc2.d/S99nc
Edit configurable items as needed.
sudo
should be used where configured. To avoid Trojan Horse
programs, su
should always be called by full path
/bin/su. % ./S99nc start
% ./S99nc status
% ./S99nc stop
