Job Fostering
Job fostering is the processes of artificially consuming a job slot on a tasker in order to represent an externally running job or process.
The vovfosterjob utility runs as a job on a tasker and monitors an external job or process. When the external job or process exits, the vovfosterjob utility will also exit, freeing up the slot in which it was running.
vovfosterjob
vovfosterjob: Usage Message
    DESCRIPTION:
      A system utility to tell a slave to watch a PID or a JOB by creating
      a foster job that runs for the lifetime of the entity being watched.
      Resulting foster jobs are stored in the System:Orphanage set, which
      can be displayed by passing the set name to 'nc list -alljobs -set'.
      This utility is mainly used to prevent overloading of a slave that
      has been started on a host that also has a slave in the process of
      shutting down gracefully. Such slaves will only exit once any jobs
      running on them are complete. Fostering such jobs onto the newly started
      slave will result in job slots being consumed, preventing additional
      jobs from landing on the host.
    OPTIONS:
      -h                   -- Display usage help.
      -v                   -- Increase output verbosity. Repeatable.
      -pid       PID       -- Foster a process. Without the -host or -toslave
                              option, the resulting foster job will be dispatched
                              to the first slave found that is running on the same
                              host where the vovfosterjob command is executed. If
                              the PID does not exist, the foster job will be
                              created but will exit immediately.
                              Compatible with the -host and -toslave options.
      -host      HOSTNAME  -- Specify host to which the foster job should be
                              dispatched. The resulting foster job will be
                              dispatched to the first slave found on the
                              specified host.
                              Compatible with the -pid and -job options.
      -job       JOBID     -- Foster a job. Without the -host or -toslave option,
                              the resulting foster job will be dispatched to the
                              first slave found that is running on the same host
                              as the job being fostered.
      -fromslave SLAVENAME -- Foster all jobs on specified slave. Normally used
                              to foster jobs on a slave that has been requested
                              to gracefully stop after its jobs are finished. This
                              helps to prevent overloading if the slave is
                              restarted before the job attrition process is
                              complete.
                              Compatible only with, and requires, the -toslave
                              option.
      -toslave   SLAVENAME -- Specify slave to which the foster job should be
                              dispatched. Compatible with the -pid, -job, and
                              -fromslave options.
      -stoppedslaves SLAVENAME --
                              Foster jobs running on all prior instances of the
                              specified slave that are in the process of stopping
                              gracefully. The resulting foster jobs will be
                              dispatched to the specified slave. Not compatible
                              with any other option.
    EXAMPLES:
      % vovfosterjob -job 000123456
      % vovfosterjob -job 000123456 -toslave titan
      % vovfosterjob -pid 6789
      % vovfosterjob -pid 6789 -host titan
      % vovfosterjob -fromslave titan_stopped -toslave titan
      % vovfosterjob -stoppedslaves titan
